See through ground, 4.1
1118
12-20-2016 11:53 AM
KyleDunaway
Using a WebScene, how do I enable the "See through ground" option?
The AGOL viewer and PRO viewer have this functionality, so I know it exists, just can't seem to find the right property to set.
KyleDunaway
The property is basemapTerrain.opacity, change it from 1 to 0
KyleDunaway
nie
The similar functionality is SceneView.basemapTerrain.wireframe, but the opacity property you mentioned is much more useful to me !
LuChen
In 4.6, which object do I apply these property to? can't find either of the two in the reference.
FrancoisMartin
It is the same code, in the require and function at the beginning of your script it is needed to add "esri/basemap" (even if yourself have not added any basemap in your local scene), then after the variable creating a "new SceneView" you add  SceneViewVariableName.basemapTerrain.opacity = 0 as said above.
