Search Widget
492
03-20-2020 09:47 AM
jaykapalczynski
I have a search widget in my app.
After the search widget address is applied I have it run some code to return features within a certain distance.
This all works great....
// SEARCH WIDGET
var searchWidget = new Search({
   view: view,
   popupEnabled: false
searchWidget.on("select-result", function () {
   searchRadius();
But what I want to do is pass the Search Widget an Address not manually enter it in the widget.
I want to read from a table and pass the individual addresses to the search widget and get the result from the code that have written.
Can I pass the searchWidget an address? If so an examples out there?
jaykapalczynski
jaykapalczynski
RobertScheitlin__GISP
Jay,
   In case that does not get you there, The method on the search widget is called search.
https://developers.arcgis.com/javascript/latest/api-reference/esri-widgets-Search.html#search
jaykapalczynski
yea the answer for the link that I posted was the same
var searchWidget = new Search{view: view1})
function mySubmitFunction () {
  let element = document.getElementById("YourInputID")
  let address = element.value
  searchWidget.search(address).then((results) => {
     console.log("Search widget results :", results)
