I am using the search widget and successfully...
I can set the scale after a result is returned as such.
If I do not set the scale as seen below it still zooms to the result of the search widget.
But I want to disable the zoom completely....is there a way to do this...I have not seen anything in the documentation
searchWidget.on("select-result", function(event) {
view.goTo({
scale: 3000000
Solved! Go to Solution.
Hi Jay,
Check out the goToOverride property on the Search widget. This allows you to override the goTo() method invoked when a result is selected. Hope this helps!
Anne
Hey jay kapalczynski,
I'll be honest it has been a while since I have written js. Could you use Map | API Reference | ArcGIS API for JavaScript 3.31 and just pass it the current maps zoom scale?
I'm sure someone will have a much better answer but this could be a quick workaround.
Ben
If this answer was helpful please mark it as helpful. If this answer solved your question please mark it as the answer to help others who have the same question.
Hi Jay,
Anne
