SceneView Crashing Sometimes
907
02-19-2019 04:14 PM
TylerWaring
Occasional Contributor II
Greetings,
I've written a react application that requires a SceneView.  About every 20th refresh the application maxes out my memory and crashes. I can write the whole application with a MapView instead and everything is fine. I also get an error each time I load the SceneView:
[esri.core.Accessor] Accessor#set Assigning an instance of 'esri.views.ui.DefaultUI' which is not a subclass of 'esri.views.ui.3d.DefaultUI3D'
Does this error have anythign to do with the memory being maxed out every so often?
The code I'm working with is :
import React, { Component} from 'react'
import EsriLoaderReact from 'esri-loader-react'
import MapOverlayPanel from '../../molecules/MapOverlayPanel/MapOverlayPanel'
import './ESRIScene.css'
class ESRIScene extends Component {
  constructor(props){
    super(props)
    this.state = {
        SceneView: null
        , searchResultGL:null
    this.loadMap = this.loadMap.bind(this);
  loadMap = ({loadedModules: [WebScene, SceneView, Locate, GraphicsLayer, DefaultUI], containerNode}) => {
    const self = this
    let map = new WebScene({
        portalItem: { // autocasts as new PortalItem()
    new SceneView({
      container: containerNode
      ,id:'sv'
      , map: map
      , ui: new DefaultUI()
      , camera: {
          position: {
            x:  -117.185087,
            y: 32.715736,
            z: 300,
            spatialReference: {
              wkid: 4326
          heading: 90,
          tilt: 77.5
    .when(function(view){
      self.setState({SceneView: view})
      view.ui.padding = { top: 96, left: 21, right: 21, bottom: 0 }
      if (window.matchMedia("(min-width: 770px)").matches) {
        view.ui.components=["zoom", "navigation-toggle", "compass"];
      view.on('click', function(e){
        console.log('thi click has arrived: ' + JSON.stringify(e.mapPoint));
      let searchResultGL = new GraphicsLayer()
      self.setState({searchResultGL:searchResultGL});
      view.map.add(searchResultGL)
  render() {
    const options = {
      url: 'https://js.arcgis.com/4.10/'
    return (
      <div className="ESRIScene">
        <EsriLoaderReact
          options={options}
          modulesToLoad={['esri/WebScene', 'esri/views/SceneView', 'esri/widgets/Locate', 'esri/layers/GraphicsLayer', 'esri/views/ui/DefaultUI']}
          onReady={this.loadMap}
        <MapOverlayPanel
          ref ='mapOverlay'
          sceneView={this.state.SceneView}
          searchResultGL={this.state.searchResultGL}
          resultPinDragable={true}
      </div>
export default ESRIScene;‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Any words of wisdom will be greatly appreciated.
Tyler
BirajaNayak
Hi Tyler,
If you write the sample application using  ArcGIS Java Script API for same scene and let us know whether it still crashed during preview.
Can you use the  scene view from this below sample and let us know your observation:
ArcGIS API for JavaScript Sandbox
Biraja
TylerWaring
Hi Biraja Nayak‌,
Thank you for the suggestion. I will try to recreate this this weekend and report back to you with the results.
Thanks, Tyler
JaydeepMistry1
New Contributor II
Hello,
I am experiencing this issue with the SceneView myself. It runs fine for most of the time, but it just keeps on consuming more RAM as I keep moving the scene. Eventually leading the webpage to crash after 20-30 minutes. Has there been any update or fixes for the crashing?
I need to use a WebScene because I need to render some WebStyleSymbols points, and I can't seem to render them when using a Map instead.
Jaydeep
