As the title says, so when using RouteResult.fromJSON() it returns and objects with properties set in null.
Here is a sample
RouteResult.toJSON() sample The problem is in Line 113 and 115. Please read them.
Am I doing something wrong?
Juan,
Your code pen worked fine for me. I clicked two point in the extent that comes up when the app loads and logged in with my credentials and it produced a route without any issue.
I have no problem with the route being solved. The real problem is in lines 113 and 115 when getting a RouteResult object because I need to convert it to JSON using toJSON() method but it doesn't work, it returns an empty object (Line 113) and then when I try to convert it again to a normal RouteResult object (Line 115) it returns a RouteResult object but with null properties (useless).
Click two points in map then watch the browser console.
Juan,
The route result is NOT json it is a RouteResult object
RouteResult | API Reference | ArcGIS API for JavaScript 4.9
So your code would need to look something like this, after requiring the dojo/json module
function showRoute(data) {
var routeResult = data.routeResults[0].route;
var routeResultJSON = JSON.stringify(routeResult);
console.log(routeResultJSON);
console.log(JSON.parse(routeResultJSON));
routeResult.symbol = routeSymbol;
routeLayer.add(routeResult);
