route event changes show only with service restart
2909
18
09-19-2013 07:44 AM
by Anonymous User
Not applicable
Original User: jrutkowski
I have a feature layer which is a route event. When the table is updated with the TO and FROM values and so on, the new route will not show in the map until I restart the service.
Any suggestions? Thanks!
by Anonymous User
Not applicable
Original User: matt2222
I had a similar issue.
See if this thread helps you at all.
http://forums.arcgis.com/threads/88873-Dynamic-map-service-not-updating
JoeRutkowski
I am using and SDE table in SQL Server... I am trying to allow the user to edit the table via the application. It is something i have done in the past with XY point events, but it seems route events require the editing to be done via ArcMap editing rather than straight SQL inserts. How are you editing your data?
by Anonymous User
Not applicable
We have an application that pushes mile marker points and other data into a SQL database.
Then every 5 minutes we have a python script that takes that data, dynsegs it and appends it to a feature class in a FGDB.
JohnGravois
maybe it would be helpful to post in the ArcGIS Server forum directly?  this doesn't actually appear to by a JS API issue...
that being said, if you are updating a table outside of the ArcGIS world, this KB article might be helpful to check out.
FAQ:  How are updates to event layers handled in ArcGIS Server?
http://support.esri.com/en/knowledgebase/techarticles/detail/34350
by Anonymous User
Not applicable
Original User: bbieb
Here is the information for ArcGIS Server 10.1.  I've been trying to get Esri to update the article for 10.2 but so far no luck.
http://support.esri.com/cn/knowledgebase/techarticles/detail/25846
JoeRutkowski
the 10.1 link is down for server maintenance... looks promising though!
by Anonymous User
Not applicable
Original User: JSkinn3
Hi Joe,
I ran into a similar issue working with a customer.  Along with the KB article that Brad mentioned, I also had to run through the steps in the following KB article:
The KB article does not mention this, but at 10.1 you will also need to set the 'UseOptimization' DWORD decimal value to 0, under the DynSeg key for the Server10.1 folder:
HKEY_USERS\.DEFAULT\Software\esri\Server10.1\DynSeg
HKEY_CURRENT_USER\Software\ESRI\Server10.1\DynSeg\UseOptimization
bbieb
Corrected the link in the post.
brian
brian
by Anonymous User
Not applicable
Original User: jgravois
@Brian/ et al.,
i would assume that the 10.1 article (in tandem with the information provided by Jake) would result in desirable behavior in 10.2 as well, because the root architecture is the same as 10.1.
