ROTATION not working on IconSymbol3DLayer
580
07-15-2021 03:11 AM
MichaelK1
New Contributor III
I want to rotate the icon symbol like (in SceneView):
symbol: {
type: 'point-3d', // autocasts as new PointSymbol3D()
symbolLayers: [
type: 'icon',
resource: {
href: './assets/images/triangle.png',
visualVariables: [
type: 'rotation',
field: 'heading',
rotationType: 'geographic',
My Feature layer elevationInfo mode is : on-the-ground
But it's not working, is it possible to rotate an icon based on visual variable?
If not how am I supposed to do this?
Thanks
SaschaBrunnerCH
Hi Michael
This is a known limitation and mentioned here: https://developers.arcgis.com/javascript/latest/api-reference/esri-renderers-visualVariables-Rotatio...
"In a SceneView rotation visual variables are not currently supported with marker symbols, text symbols, 3D icon symbol layers and 3D text symbol layers."
You could use ObjectSymbol3DLayer . See also the sample:
https://developers.arcgis.com/javascript/latest/sample-code/layers-featurelayer-labeling-3d/
Would that work for your use case? Otherwise can you let us know what your use case is.
Thanks.
MichaelK1
New Contributor III
Hi Sascha
Thanks
I could use ObjectSymbol3D objects for displaying 'my triangles' (with the correct rotation). But these 3d objects have a fixed size based on the map. Is it possible to scale those like markers?
