Return nearest feature within same feature layer using Arcade
1169
02-02-2021 12:53 PM
AFackler_NAPSG
I am trying to create an Arcade script that, within the pop-up, will return the next closest feature within the same layer. In my case, if I click on a wildfire point, it will tell me what the next closest wildfire point is. I have has some success changing up the script found in lines 30-44 here, but what I have found is that my current script returns the point that is furthest from the selected point within the search distance. Any guidance on what I can do?
var searchDistance =50;
var points = $layer
var closestPoint = Intersects(points, BufferGeodetic($feature, searchDistance, "Miles"));
var minDistance = Infinity
for(var listing in closestPoint){
    var facilityDistance = Distance(listing, $feature, "miles");
    if (facilityDistance < minDistance){
        closestPoint = listing;
            return closestPoint.iaName
XanderBakker
Esri Esteemed Contributor
Hi @AFackler_NAPSG ,
You have to update the minimum distance and as @KenBuja  pointed out you have to put the return outside the for loop.
var searchDistance = 50;
var points = $layer;
var CurrentiaName = $feature.iaName;
var closestPoints = Intersects(points, BufferGeodetic($feature, searchDistance, "Miles"));
var minDistance = Infinity;
for(var pnt in closestPoints){
    var facilityDistance = DistanceGeodetic(pnt, $feature, "miles");
        if (CurrentiaName != pnt.iaName) {
            closestPoint = pnt;
            minDistance = facilityDistance;
return closestPoint.iaName;
 Furthermore, you have to avoid returning the same input feature. You could do this by checking for an ID (I used the iaName in this case.
KenBuja
MVP Esteemed Contributor
Give this a try
var points = $layer
var closestPoint;
for(var listing in closestPoints){
return closestPoint;
XanderBakker
            closestPoint = pnt;
AFackler_NAPSG
Thank you @KenBuja and @XanderBakker !
