Hello, I am asking if there is a way to create a WMSLayer from a WMS url. I am under the following constraints
A) I cannot use the proxy solution as our production infrastructure does not allow outbound communications B) The WMS URL is not within our network domain, so I am facing 'same site origin policy' issues
Does anyone know of another way to consume an external WMS service.
Secondly, if I do, somehow, get the XML data from the WMS service, is there a way to create the WMSLayer object by supplying the raw XML data and no URL.
As per ArcGIS JS api documentation of WMS layer class: "The default behavior of a WMSLayer is to execute a WMS GetCapabilities request, which requires using a proxy page. An alternate approach is to pass a resourceInfo object into the constructor which does not require a GetCapabilities request. "
So if you pass resourceInfo it should not use proxy page.
Hello Rahul, Thnak you for you help. I can now display the WMS map using the resourseInfo. However if I set the baseMap of my map object to 'streets' the WMS map does not show anymore.
