Retrieve single column data of a feature layer .
2978
12
12-02-2018 01:48 AM
Jayendra_Praveen_KumarChorapal
Hey i am working on a feature layer and i would like to have the all the tuple values of a single column of my feature layer so that i will use these tuples to insert in a drop down list for my web app. I hope for a quick reply.
RobertScheitlin__GISP
Jayendra,
Getting values from a single column is a fairly simple task with a QueryTask in the JS API.
The returned value of a QueryTask is a FeatureSet (which is an Array of Graphics) a tuple is something in Python and other languages though, not JavaScript.
require([
  "esri/tasks/query", "esri/tasks/QueryTask", ...
], function(Query, QueryTask, ... ) {
  var query = new Query();
  var queryTask = new QueryTask( ... );
  query.where = "STATE_NAME = 'Washington'";
  query.outSpatialReference = {wkid:102100};
  query.returnGeometry = true;
  query.outFields = ["CITY_NAME"];
  queryTask.execute(query, addPointsToMap);
This will return the CITY_NAME filed from the Map Service that has a STATE_NAME of Washington.
Jayendra,
require([
Sir,
The table of my feature layer has been attached under this.I would like
to retrieve the NAME_OF_THE_SCHOOL column data of that table and insert
each value of that column in a drop down list in my website.As far as your
concerns about selecting a particular record in a column but i would like
to retrieve the entire column data.
I hope for a quick reply sir.
On Mon, Dec 3, 2018 at 10:09 AM Robert Scheitlin, GISP <geonet@esri.com>
Jayendra,
   OK, So here is a full sample for adding a fields unique values to a dropdown.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/4.9/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/Map",
      "esri/views/MapView",
      "dojo/on",
      "esri/tasks/support/Query",
      "esri/layers/FeatureLayer",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/parser",
      "dijit/registry",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, MapView, on, Query, FeatureLayer, Memory, array, lang, esriRequest, parser, registry
      parser.parse();
      map = new Map({
        basemap: "topo"
      var view = new MapView({
        container: "map",
        map: map,
        center: [-98.1883, 37.0868],
        zoom: 5
      esriRequest('http://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/3/query?where=1%3D1&outF...',
        responseType:'json',
        timeout:15000
      }).then(lang.hitch(this,function(response){
        var store2 = new Memory({data:[]});
        registry.byId("stateSelect").set('store',store2);
        var data = array.map(response.data.features,lang.hitch(this,function(feat, index){
          var name = feat.attributes.STATE_NAME;
          var value = feat.attributes.STATE_NAME;
          var dataItem = {
            value:value
          return dataItem;
        store2 = new Memory({data:data});
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a State:
      <input id="stateSelect" data-dojo-type="dijit/form/ComboBox" value="Select State"  data-dojo-props="maxHeight: 200" />
      <input type="hidden" name="stateabbr" id="stateabbr" />
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
Sir,
My application is real time sir the values of my column keeps on increasing
if schools get registered .
so i cant directly give the json url in my code because it only has the
school data at that point of time . if any new school gets registered in my
website i cant find them in the drop down list.
can u please provide me a solution for this.
On Mon, Dec 3, 2018 at 10:43 AM Robert Scheitlin, GISP <geonet@esri.com>
So that what i would like perform query for retrieving the single column
data and i will generate a drop down list of that data
What actually im looking is a line that seems to be SELECT
NAME_OF_THE_SCHOOL from TABLENAME as in sql which gives all the records in
that column
On Mon, Dec 3, 2018 at 11:59 AM Chorapalli Jayendra praveen kumar <
Jayendra,
  You do not have the ability to do a raw SQL select in the JavaScript API. you only have access to the Where clause portion of the SQL.
Have you seen the JS API documentation?
JS API 3.x
QueryTask | API Reference | ArcGIS API for JavaScript 3.26
Query | API Reference | ArcGIS API for JavaScript 3.26
JS API 4.x
QueryTask | API Reference | ArcGIS API for JavaScript 4.9
Query | API Reference | ArcGIS API for JavaScript 4.9
Sir thank you for the information.
and While accessing directions through sandbox
It is asking my Arcgis online credentials and I’ve entered the esri
provided and things are going good in sandbox
But when I use the code in my document and just try to open it in a browser
It’s asking for Arcgis online credentials and I’m entering the same
credentials that esri provided which I’ve entered in the sandbox but the
popup box is saying that the username and password are incorrect ?
I am having credits in my account too.
My credentials are working in sandbox and Arcgis Devlabs also
But when loading the same code in a file and trying it open it in a browser
the popup is notifying me that the invalid username and password.
I dont know whats wrong is going with the same code.
Looking forward for your reply sir
On Mon, Dec 3, 2018 at 7:41 PM Robert Scheitlin, GISP <geonet@esri.com>
Sir,
In the sample code
there is a hidden input field and i would like to use it use it as text
field used to display the selected elements value in drop-down list.
I have tried but its not working.
I hope you help me out from this. here im trying to show the emil of the
school selected from the drop downlist
esriRequest('
https://services9.arcgis.com/2882Ggz2LB0PQSyP/arcgis/rest/services/school/FeatureServer/0/query?where=OBJECTID%3E0&objectIds=&time=&geometry=&geometryType=esriGeometryPoint&inSR=&spatialRel=esriSpatialRelIntersects&resultType=none&distance=0.0&units=esriSRUnit_Meter&returnGeodetic=false&outFields=NAME_OF_THE_SCHOOL%2CEMAIL_ADDRESS_OF_THE_SCHOOL&returnHiddenFields=false&returnGeometry=false&multipatchOption=xyFootprint&maxAllowableOffset=&geometryPrecision=&outSR=&datumTransformation=&applyVCSProjection=false&returnIdsOnly=false&returnUniqueIdsOnly=false&returnCountOnly=false&returnExtentOnly=false&returnDistinctValues=false&orderByFields=&groupByFieldsForStatistics=&outStatistics=&having=&resultOffset=&resultRecordCount=&returnZ=false&returnM=false&returnExceededLimitFeatures=true&quantizationParameters=&sqlFormat=none&f=pjson&token=XOpDCWQjd4GHcexTq23FjrCNDHt8CVYZI4-g2KhpaPEuwP8hpnWtUiH2FK1zh7wsfKJ8-Y3G4cHl1v_M-AWfFBZsH7PS9n3wp-F8ZhDddn5lJ5ukhKRnyHp5mvkJ6fyx61GD28PFbw6cAH5FA7mubsYcsjj-L5poA9KyBWSmZfknKJ41pYXSOa0-d7IeIfUyZuBkdkx0poaUttA1Bkdj8Hzm3jdvxLRe_Ke-UoPuHv_wsAJgoq3rJatPvwnSNYAU
).then(lang.hitch(this, function (response) {
var store2 = new Memory({ data: [] });
registry.byId("stateSelect").set('store', store2);
var data = array.map(response.data.features, lang.hitch(this, function
(feat, index) {
var name = feat.attributes.NAME_OF_THE_SCHOOL;
var value = feat.attributes.EMAIL_ADDRESS_OF_THE_SCHOOL;
alert(value);
var dataItem = {
value: value
// console.log(dataItem.value);
return dataItem;
store2 = new Memory();
On Wed, Dec 5, 2018 at 5:18 PM Chorapalli Jayendra praveen kumar <
Jayendra,
 When your original question has been answered you should mark the question as answered by licking on the "Mark Correct" link on the reply that answered your question.
Then if you have another question you start a new question and ask there. If you do decide to start a new thread make sure you specify if you want the EMAIL_ADDRESS_OF_THE_SCHOOL to be shown in the dropdown or the NAME_OF_THE_SCHOOL.
