Resize and Reposition Map
4432
7
03-11-2016 07:55 AM
JohnPreston
I would like to resize and reposition map div and map after user clicks button. When page loads map is positioned to float right with taking up a certain % of page. I would like to reposition map to left and set size to specific #. I can move the map and resize, however the map layers do reposition in center. I'm sure I missing something. Here is my code...
onClick: function () {
$('#left_col').hide();
$('#right_col').css("float", "left");
$('#right_col').css("width", "500px");
$('#right_col').css("height", "500px");
$('#map').css("float", "left");
$('#map').css("width", "500px");
$('#map').css("height", "500px");
map.width = 1000;
map.height = 500;
map.resize();
map.reposition();
TyroneBiggums
Occasional Contributor III
Your map width is 1000 but the containing map div is 500px.
JohnPreston
I tried making them both 500, however the map doesn't resize at all. With the code I posted the map actually resized but didn't reposition.
When I do change to both to 500, and I pan just a little the map then repositions in center (does that make sense)?
TyroneBiggums
Height and width are read-only for the map. Remove map.width and map.height. Your map is in a containing div, right? #right_col or #map? Just resize the containing div.
Map | API Reference | ArcGIS API for JavaScript
JohnPreston
I took out map.width and map.height, now map doesn't resize. The map is contained in #map, the #map div is contained in #right_col.
TyroneBiggums
Seeing more code might be helpful. I'm not picturing what's happening. You're moving right_col to the left side of the window?
Are the right_col dimensions changing?
Are you AMD?
Are you checking to see if the dom is ready after stuff is moved around? The sync/async stuff can get screwy at times. Your map may have resized before the dom was ready (before your right_col moved).
What version of the API?
JohnPreston
Thanks Tyrone
I got it to behave the way I want. However when I add graphics to map and/or separate graphics layer they are not being redrawn correctly. They graphics are not in the correct position and are distorted. Do I need to update extent? Some other setting?
$('#printPane').hide();
$('#right_col').css("width", "700px");
$('#map').css("width", "700px");
map.width = 700;
map.resize();
map.reposition();
TyroneBiggums
I'd probably need to see more code to replicate and see what you mean. And, you have map.width, the read-only property, set to 700. I'm not sure how much that helps you or how much it hinders you.
