Remove layers from the layerWidget
2427
04-17-2019 01:01 AM
KennethLindhardt1
Occasional Contributor II
Hi, I’m new to JavaScript, but are starting to get a need app build up, with the help from GeoNet. I’ve used the layerWidget, but some layers I need to hide in the widget. I would expect to use the listMode property to do that, but I can’t seem to hit the right syntax to do so.
I’m creating a SceneView with a WebScene, and the layerWidget shows all of those layers.
      var layerWidget = new LayerList({
          view: sceneView,
          container: "layerPanelDiv"
But if I want the layer widget not to show a layer from the scene called Cars, so the end user not will be able to turn it off or even see that it exist, how do I do so?
Thanks.
KenBuja
This code (lines 49-54) hides a specific layer in a WebScene from the LayerList widget. Compare it with the original sample. This code comes from this discussion.
<!DOCTYPE html>
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1, maximum-scale=1,user-scalable=no"
    <title>LayerList widget - 4.11</title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.11/esri/themes/light/main.css"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script src="https://js.arcgis.com/4.11/"></script>
    <script>
      require([
        "esri/views/SceneView",
        "esri/widgets/LayerList",
        "esri/WebScene"
      ], function(SceneView, LayerList, WebScene) {
        var scene = new WebScene({
          portalItem: {
            // autocasts as new PortalItem()
        var view = new SceneView({
          container: "viewDiv",
          map: scene
        view.when(function() {
          var hideLayer = view.map.layers.flatten(function(item){
            return item.layers || item.sublayers;
          }).find(function(layer){
            return layer.title === "Buildings";
          hideLayer.listMode = "hide";
          var layerList = new LayerList({
            view: view
          // Add widget to the top right corner of the view
          view.ui.add(layerList, "top-right");
    </script>
  </head>
  <body class="calcite">
    <div id="viewDiv"></div>
  </body>
</html>
KenBuja
<!DOCTYPE html>
<html>
  <head>
    <meta
      name="viewport"
    <link
      rel="stylesheet"
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
        overflow: hidden;
    </style>
    <script>
      require([
        "esri/WebScene"
          portalItem: {
          map: scene
            view: view
    </script>
  </head>
  </body>
</html>
KennethLindhardt1
Thank you so much, was going back and forward that example, but couldn’t make it fit. Now it works, thank you.
KenBuja
Glad to help. Don't forget to click the "Mark Correct" button.
