React with react-arcgis
600
03-28-2019 05:14 AM
kawishabbas
My App is built with react and i want to use Arcgis API 3.27 into this project. i have downloaded react-arcgis but it install latest verison of API 4.10. How can i use API 3.27 instead of 4.10 in react
ReneRubalcava
The steps are similar, but you can't use the react-arcgis library, there is no 3x version of it.
I don't know of any samples of 3x with React, but the ideas are the same, you probably want to use esri-loader because we don't have a webpack plugin for 3x. You can create a component and when the component mounts you can reference the output DOM node and attach your map to it.
kawishabbas
Thank you Rene Rubalcava.
