Re: Move ArcGis JS API Graphic Point
1321
11-14-2018 02:14 AM
EssaddekMohammed
Hello Robert, this worked for me.
Is there any way to apply this behavior to search widget result?
Regards.
Branched from https://community.esri.com/message/809739-re-move-arcgis-js-api-graphic-point
RobertScheitlin__GISP
Here is the code modified to edit a search result.
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Intro to graphics - 4.9</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    var isSearchGra = false;
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/widgets/Sketch/SketchViewModel",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/support/webMercatorUtils",
      "esri/geometry/Polygon",
      "esri/geometry/Polyline",
      "esri/widgets/Search"
    ], function(
      Map, MapView, SketchViewModel, Graphic, GraphicsLayer, webMercatorUtils, Polygon, Polyline, Search
      let editGraphic;
      // GraphicsLayer to hold graphics created via sketch view model
      const graphicsLayer = new GraphicsLayer({
      const map = new Map({
        basemap: "gray",
        layers: [graphicsLayer]
      const view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 3
      var searchWidget = new Search({
        view: view
      // Add the search widget to the top right corner of the view
      view.ui.add(searchWidget, {
        position: "top-right"
       * Create a point graphic
      // First create a point geometry (this is the location of the Titanic)
      var point = {
        type: "point", // autocasts as new Point()
        longitude: -49.97,
        latitude: 41.73
      // Create a symbol for drawing the point
      var markerSymbol = {
        type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
        color: [226, 119, 40],
        outline: { // autocasts as new SimpleLineSymbol()
          color: [255, 255, 255],
          width: 2
      // Create a graphic and add the geometry and symbol to it
      var pointGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(point),
        symbol: markerSymbol
       * Create a polyline graphic
      // First create a line geometry (this is the Keystone pipeline)
      var polyline = Polyline({
        type: "polyline", // autocasts as new Polyline()
        paths: [
          [-111.30, 52.68],
          [-98, 49.5],
          [-93.94, 29.89]
      // Create a symbol for drawing the line
      var lineSymbol = {
        type: "simple-line", // autocasts as SimpleLineSymbol()
        width: 4
       * Create a new graphic and add the geometry,
       * symbol, and attributes to it. You may also
       * add a simple PopupTemplate to the graphic.
       * This allows users to view the graphic's
       * attributes when it is clicked.
      var polylineGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(polyline),
        symbol: lineSymbol
       * Create a polygon graphic
      // Create a polygon geometry
      var polygon = Polygon({
        type: "polygon", // autocasts as new Polygon()
        rings: [
          [-64.78, 32.3],
          [-66.07, 18.45],
          [-80.21, 25.78],
          [-64.78, 32.3]
      // Create a symbol for rendering the graphic
      var fillSymbol = {
        type: "simple-fill", // autocasts as new SimpleFillSymbol()
        color: [227, 139, 79, 0.8],
          width: 1
      // Add the geometry and symbol to a new graphic
      var polygonGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(polygon),
        symbol: fillSymbol
      const pointSymbol = {
        style: "square",
        color: "#8A2BE2",
          width: 3
      const polylineSymbol = {
        type: "simple-line", // autocasts as new SimpleLineSymbol()
        color: "#8A2BE2",
        width: "4",
        style: "dash"
      const polygonSymbol = {
        color: "rgba(138,43,226, 0.8)",
        style: "solid",
        outline: {
          color: "white",
          width: 1
      view.when(function () {
        // Add the graphics to the view's graphics layer
        graphicsLayer.graphics.addMany([pointGraphic, polylineGraphic, polygonGraphic]);
        // create a new sketch view model
        const sketchViewModel = new SketchViewModel({
          view,
          layer: graphicsLayer,
          pointSymbol,
          polylineSymbol,
          polygonSymbol
        setUpClickHandler();
        // Listen the sketchViewModel's update-complete and update-cancel events
        sketchViewModel.on("update-complete", updateGraphic);
        sketchViewModel.on("update-cancel", updateGraphic);
        // Runs when sketchViewModel's update-complete or update-cancel
        // events are fired.
        function updateGraphic(event) {
          // Create a new graphic and set its geometry event.geometry
          var graphic = new Graphic({
            geometry: event.geometry,
            symbol: editGraphic.symbol
          if(isSearchGra){
            graphic.attributes = editGraphic.attributes;
            view.graphics.add(graphic);
          }else{
            graphicsLayer.add(graphic);
          // set the editGraphic to null update is complete or cancelled.
          editGraphic = null;
        // set up logic to handle geometry update and reflect the update on "graphicsLayer"
        function setUpClickHandler() {
          view.on("click", function (event) {
            view.hitTest(event).then(function (response) {
              var results = response.results;
              if (results.length > 0) {
                for (var i = 0; i < results.length; i++) {
                  // Check if we're already editing a graphic
                  var gra = results[i].graphic;
                  if(!editGraphic && gra.attributes && gra.attributes.hasOwnProperty("Match_addr")){
                    isSearchGra = true;
                    editGraphic = results[i].graphic;
                    view.graphics.remove(editGraphic);
                    sketchViewModel.update(editGraphic);
                    break;
                  }else if (!editGraphic && gra.layer.id === "tempGraphics") {
                    // Save a reference to the graphic we intend to update
                    // Remove the graphic from the GraphicsLayer
                    // Sketch will handle displaying the graphic while being updated
                    graphicsLayer.remove(editGraphic);
                    break;
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Essaddek,
   Probably, but you should really mark this question as answered, by clicking on the "Mark Correct" link on the reply that answered your question
before you ask a another separate question.
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
    ], function(
      let editGraphic;
        basemap: "gray",
        map: map,
        zoom: 3
        view: view
      var point = {
        longitude: -49.97,
        latitude: 41.73
          width: 2
        paths: [
          [-111.30, 52.68],
          [-98, 49.5],
          [-93.94, 29.89]
      var lineSymbol = {
        width: 4
        symbol: lineSymbol
        rings: [
          [-64.78, 32.3],
          [-66.07, 18.45],
          [-80.21, 25.78],
          [-64.78, 32.3]
      var fillSymbol = {
          width: 1
        symbol: fillSymbol
        style: "square",
        color: "#8A2BE2",
          width: 3
        color: "#8A2BE2",
        width: "4",
        style: "dash"
        style: "solid",
        outline: {
          color: "white",
          width: 1
          view,
          pointSymbol,
          polylineSymbol,
          polygonSymbol
          if(isSearchGra){
          }else{
          editGraphic = null;
                    isSearchGra = true;
                    break;
                    break;
  </script>
</head>
<body>
</body>
</html>
