"Error executing tool. Export Web Map Task" on secure layer
7005
11
01-30-2018 12:05 PM
Travis_L_Riffle
I saw this question asked in a different part of the forums and it was never answered.  I am having the same issue.
I am trying to use the print widget to print a secure map (per the below example of a secure map).  None of our stuff is on-prem, it's all ESRI cloud.
I am using a proxy from GitHub - GitHub - Esri/resource-proxy and all calls work fine - except the print widget when attempting to export a SECURE map.  I have ensured my credentials were working correctly.
{"error":{"code":400,"message":"Unable to complete operation.","details":["Error executing tool. Export Web Map Task : Layer \"2016 USA Population Density\": Unable to connect to map server at https://demographics6.arcgis.com/arcgis/rest/services/USA_Demographics_and_Boundaries_2016/MapServer... to execute (Export Web Map).\nFailed to execute (Export Web Map Task)."]}}
Thanks in advance,
T
ChrisSmith7
Travis,
Do you have anything set-up for allowedReferers or mustMatch?
ChrisSmith7
Hey Travis,
I just tried loading your secured layer to see what would happen... something interesting... I'm not sure it's related, but I got into an infinite redirect loop:
Travis_L_Riffle
<ProxyConfig allowedReferers="*"
mustMatch="true">
ChrisSmith7
by Anonymous User
Not applicable
Hi Chris,
Print maps that contain secured services—Documentation (10.5) | ArcGIS Enterprise
It's working for me.
Or you can put token to your Web_Map_as_JSON parameter.
Travis_L_Riffle
Are you on prem?
Travis_L_Riffle
This is for on-prem.  I am trying to accomplish this through ARCGis cloud services only.
Our webapp calls into the proxy which then calls the print service.
by Anonymous User
Not applicable
You can try to modify Web_Map_as_JSON parameter, service url to "http://yourhost/proxy/proxy.ashx?service_url".
Travis_L_Riffle
I'll try to find this in the API and see if this has an affect.
