The problem is associated with how the ArcGIS server (python) handles floating point numbers: 14. Floating Point Arithmetic: Issues and Limitations — Python 2.7.11 documentation
As far as I know, the only recourse is to round the result.
Can you please share the solution, if you got any?
It depends on what you are trying to achieve. For e.g. If you want to round them in InfoWindow. The popup template has options which you can set to show only that number of places.
