Query Features Sample Code
2418
6
07-13-2021 07:12 AM
EllisHammond1
New Contributor II
Hello,
I am working on developing an application with the JS API and was using a sample code to teach myself.
The sample code was previously here: https://developers.arcgis.com/javascript/latest/sample-code/featurelayer-query/ But has since been replaced with a new example. The previous example involved querying earthquakes based on magnitude and proximity to well sites.
Does anyone know where this has gone, or alternatively does anyone have this previous sample code available to share?
I have copied my attempt to get this to work below - if anyone can help me I would be really grateful 🙂 I'm very new to HTML and JS so would welcome any hints and tips. I'm trying to create an app that allows client-side query, where users can query brownfield sites in Liverpool, based on their proximity to certain types of schools, and minimum net housing potential.
@BlakeTerhune @KenBuja I have seen that you guys have helped with this kind of thing before, hope you don't mind me tagging you.
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>Query features from a FeatureLayer</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.19/"></script>
    <style>
        html,
        body,
        #viewDiv {
          height100%;
          width100%;
          margin0;
          padding0;
        #infoDiv {
          background-colorwhite;
          colorblack;
          padding6px;
          width400px;
        #results {
          font-weightbolder;
          padding-top10px;
        .slider{
          width100%;
          height60px;
        #drop-downs{
          padding-bottom15px;
      </style>
      <script>
        require([
          "esri/Map",
          "esri/views/MapView",
          "esri/layers/FeatureLayer",
          "esri/layers/GraphicsLayer",
          "esri/geometry/geometryEngine",
          "esri/Graphic",
          "esri/widgets/Slider"
        ], function(MapMapViewFeatureLayerGraphicsLayergeometryEngineGraphicSlider) {
          var BrownfieldsUrl =
          var SchoolsBufferSchoolsGeometriesminnetdwel;
          var schoolTypeSelect = document.getElementById("TypeOfEs_1");
          var dwelSlider = new Slider({
            container: "dwel",
            min: 0,
            max: 110,
            steps: 10,
            values: [ 2 ],
            visibleElements: {
              labels: true,
              rangeLabels: true
          var distanceSlider = new Slider({
            container: "distance",
            min: 100,
            max: 10000,
            steps: 100,
            labelFormatFunction: function(valuetype){
              if (type === "value"){
                return parseInt(value);
              return value;
            values: [ 5000 ],
            visibleElements: {
              labels: true,
              rangeLabels: true
          var queryBrownfields = document.getElementById("query-brownfields");
          // schools
          var SchoolsLayer = new FeatureLayer({
            portalItem: {
              // autocasts as new PortalItem()
            outFields: ["*"],
            visible: false
          //brownfieldsites
          var BrownfieldsLayer = new FeatureLayer({
            url: BrownfieldsUrl,
            outFields: ["*"],
            visible: false
          // GraphicsLayer for displaying results
          var resultsLayer = new GraphicsLayer();
          var map = new Map({
            basemap: "hybrid",
            layers: [SchoolsLayerBrownfieldsLayerresultsLayer]
          var view = new MapView({
            container: "viewDiv",
            map: map,
            center: [53.404343, -2.986252],
            zoom: 9
          view.ui.add("infoDiv""top-right");
          // query all features from the schools layer
          view
            .when(function() {
              return SchoolsLayer.when(function() {
                var query = SchoolsLayer.createQuery();
                return SchoolsLayer.queryFeatures(query);
            .then(getValues)
            .then(getUniqueValues)
            .then(addToSelect)
            .then(createBuffer);
          // return an array of all the values in the
          // TypeOfEs_1 field of the schools layer
          function getValues(response) {
            var features = response.features;
            var values = features.map(function(feature) {
              return feature.attributes.TypeOfEs_1;
            return values;
          // return an array of unique values in
          // the TypeOfEs_1 field of the schools layer
          function getUniqueValues(values) {
            var uniqueValues = [];
            values.forEach(function(itemi) {
              if ((uniqueValues.length < 1 || uniqueValues.indexOf(item) === -1) && item !== "") {
                uniqueValues.push(item);
            return uniqueValues;
          // Add the unique values to the schools type
          // select element. This will allow the user
          // to filter schools by type.
          function addToSelect(values) {
            values.sort();
            values.forEach(function(value) {
              var option = document.createElement("option");
              option.text = value;
              SchoolTypeSelect.add(option);
            return setSchoolDefinitionExpression(SchoolTypeSelect.value);
          // set the definition expression on the schools
          // layer to reflect the selection of the user
          function setSchoolDefinitionExpression(newValue) {
            SchoolsLayer.definitionExpression = "TypeOfEs_1 = '" + newValue + "'";
            if (!SchoolsLayer.visible) {
              SchoolsLayer.visible = true;
            return queryForSchoolsGeometries();
          // Get all the geometries of the schools layer
          // the createQuery() method creates a query
          // object that respects the definitionExpression
          // of the schools layer
          function queryForSchoolsGeometries() {
            var SchoolsQuery = SchoolsLayer.createQuery();
            return SchoolsLayer.queryFeatures(SchoolsQuery).then(function(response) {
              SchoolsGeometries = response.features.map(function(feature) {
                return feature.geometry;
              return SchoolsGeometries;
          // creates a single buffer polygon around
          // the schools geometries
          var bufferGraphic = null;
          function createBuffer(SchoolPoints) {
            var bufferDistance = distanceSlider.values[0];
            var SchoolsBuffers = geometryEngine.geodesicBuffer(SchoolsPoints, [bufferDistance], "meters"true);
            SchoolsBuffer = SchoolsBuffers[0];
            if(bufferGraphic){
              bufferGraphic.geometry = SchoolsBuffer;
            } else {
              // add the buffer to the view as a graphic
              bufferGraphic = new Graphic({
                geometry: SchoolsBuffer,
                symbol: {
                  type: "simple-fill"// autocasts as new SimpleFillSymbol()
                  outline: {
                    width: 1.5,
                    color: [25512800.5]
                  style: "none"
              view.graphics.add(bufferGraphic);
          // Get the minnetdwel value set by the user
          dwelSlider.on("thumb-drag"function(event) {
            minnetdwel = event.value;
          // create a buffer around the queried geometries
          distanceSlider.on("thumb-drag"function(event) {
            if(event.state === "stop"){
              createBuffer(SchoolsGeometries);
          // set a new definitionExpression on the schools layer
          // and create a new buffer around the new schools
          SchoolsTypeSelect.addEventListener("change"function() {
            var type = event.target.value;
            setSchoolsDefinitionExpression(type).then(createBuffer);
          // query for brownfields with the specified min net dwell
          // within the buffer geometry when the query button
          // is clicked
          queryBrownfields.addEventListener("click"function() {
            queryBrownfields().then(displayResults);
          function queryBrownfields() {
            var query = BrownfieldsLayer.createQuery();
            query.where = "MinNetDwel >= " + dwelSlider.values[0];
            query.geometry = SchoolsBuffer;
            query.spatialRelationship = "intersects";
            return BrownfieldsLayer.queryFeatures(query);
          // display the brownfields query results in the
          // view and print the number of results to the DOM
          function displayResults(results) {
            resultsLayer.removeAll();
            var features = results.features.map(function(graphic) {
              graphic.symbol = {
                type: "simple-marker"// autocasts as new SimpleMarkerSymbol()
                style: "diamond",
                color: "darkorange"
              return graphic;
            var numBrownfields = features.length;
            document.getElementById("results").innerHTML = numBrownfields + " Brownfield Sites found";
            resultsLayer.addMany(features);
      </script>
    </head>
    <body>
      <div id="viewDiv"></div>
      <div id="infoDiv" class="esri-widget">
        <div id="drop-downs">
          Select school type:
          <select id="school-type" class="esri-widget"></select>
        </div>
        School buffer distance (meters):
        <div id="distance" class="slider"></div>
        Minimum Net Dwellings:
        <div id="MinNetDwel" class="slider"></div>
        <button id="query-brownfields" class="esri-widget">Query Brownfield Sites</button>
        <div id="results" class="esri-widget"></div>
      </div>
    </body>
  </html>
Noah-Sager
Hi @EllisHammond1, is this the version of the sample that you were referring to?
https://codepen.io/noash/pen/vYmgNqa?editors=1000
Older versions of the SDK, which contains the samples, are available to download by version if you have a developer's account: https://developers.arcgis.com/downloads/#javascript
Noah-Sager
EllisHammond1
New Contributor II
Hi @Noah-Sager
Yes, that's the sample - Thank you so much!
If possible, are you able to troubleshoot my code in the original post? I'm unsure as to why it's not working.
Thanks in advance for your help - really appreciate it.
BlakeTerhune
MVP Regular Contributor
There's a lot going on here that needs to be addressed. From my first pass, here are some basic issues I noticed.
  • You reference a variable "SchoolsTypeSelect" that does not exist. Probably should be SchoolTypeSelect
  • var schoolTypeSelect = document.getElementById("TypeOfEs_1");
    There is no element with an id = "TypeOfEs_1"
  • The URL defined for BrownfieldsUrl is incomplete. Maybe it should be
https://services3.arcgis.com/htbSquWCstgNlzeK/ArcGIS/rest/services/Brownfield_master_layer_v2_LivClip/FeatureServer/0​
I'll take another look if you're able to resolve those issues.
EllisHammond1
New Contributor II
Hi @BlakeTerhune ,
Thank you so much for agreeing to help me with this - I think I've corrected some of the issues.
You can find a new version here or below:
<html>
<head>
<style>
html,
body,
#viewDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
#infoDiv {
background-color: white;
color: black;
padding: 6px;
width: 400px;
#results {
font-weight: bolder;
padding-top: 10px;
.slider{
width: 100%;
height: 60px;
#drop-downs{
padding-bottom: 15px;
</style>
<script>
require([
"esri/Map",
"esri/Graphic",
], function(Map, MapView, FeatureLayer, GraphicsLayer, geometryEngine, Graphic, Slider) {
//brownfieldsites
url: "https://services3.arcgis.com/htbSquWCstgNlzeK/ArcGIS/rest/services/Brownfield_master_layer_v2_LivCli...",
outFields: ["*"],
visible: false
var SchoolsBuffer, SchoolsGeometries, minnetdwel;
var schoolTypeSelect = document.getElementById("school-type");
container: "dwel",
min: 0,
max: 110,
steps: 10,
values: [ 2 ],
visibleElements: {
labels: true,
rangeLabels: true
min: 100,
max: 10000,
steps: 100,
labelFormatFunction: function(value, type){
return value;
values: [ 5000 ],
visibleElements: {
labels: true,
rangeLabels: true
var queryBrownfields = document.getElementById("queryBrownfields");
// schools
portalItem: {
outFields: ["*"],
visible: false
var map = new Map({
basemap: "topo-vector",
layers: [SchoolsLayer, BrownfieldsLayer, resultsLayer]
map: map,
center: [-2.986252, 53.404343],
zoom: 9
view.ui.add("infoDiv", "top-right");
view
.when(function() {
.then(getValues)
.then(addToSelect)
return values;
values.forEach(function(item, i) {});
values.sort();
function createBuffer(SchoolsPoints) {
var SchoolsBuffers = geometryEngine.geodesicBuffer(SchoolsPoints, [bufferDistance], "meters", true);
if(bufferGraphic){
} else {
symbol: {
type: "simple-fill", // autocasts as new SimpleFillSymbol()
outline: {
width: 1.5,
color: [255, 128, 0, 0.5]
style: "none"
dwelSlider.on("thumb-drag", function(event) {
distanceSlider.on("thumb-drag", function(event) {
SchoolTypeSelect.addEventListener("change", function() {
// is clicked
queryBrownfields.addEventListener("click", function() {
graphic.symbol = {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
style: "diamond",
color: "darkorange"
return graphic;
</script>
</head>
<body>
Select school type:
</div>
<div id="dwel" class="slider"></div>
</div>
</body>
</html>
EllisHammond1
New Contributor II
Hi @BlakeTerhune,
Thank you so much for agreeing to help me with this - I've been working on it this morning and have gotten closer, please disregard the previous reply.
New version below and here
<html>
<head>
<title>
</title>
<link rel="stylesheet" href="https://js.arcgis.com/4.18/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.18/"></script>
<style>
html,
body,
#viewDiv {
height: 100%;
width: 100%;
margin: 0;
padding: 0;
#infoDiv {
color: black;
padding: 6px;
width: 400px;
#results {
padding-top: 10px;
.slider {
width: 100%;
height: 60px;
#drop-downs {
</style>
<script>
require([
"esri/Map",
"esri/Graphic",
], function(
Map,
MapView,
FeatureLayer,
GraphicsLayer,
geometryEngine,
Graphic,
Slider
var brownfieldsUrl =
"https://services3.arcgis.com/htbSquWCstgNlzeK/arcgis/rest/services/Brownfield_master_layer_v2_LivCli...";
var schoolBuffer, schoolsGeometries, dwelling;
container: "dwel",
min: 0,
max: 110,
steps: 10,
values: [2],
visibleElements: {
labels: true,
rangeLabels: true
min: 100,
max: 10000,
steps: 100,
labelFormatFunction: function(value, type) {
if (type === "value") {
return value;
values: [5000],
visibleElements: {
labels: true,
rangeLabels: true
var querybrownfields = document.getElementById("query-brownfields");
// oil and gas schools
var schoolsLayer = new FeatureLayer({
portalItem: {
outFields: ["*"],
visible: false
// historic brownfields
var brownfieldsLayer = new FeatureLayer({
url: brownfieldsUrl,
outFields: ["*"],
visible: false
var map = new Map({
layers: [schoolsLayer, brownfieldsLayer, resultsLayer]
map: map,
zoom: 9
view
.when(function() {
return schoolsLayer.when(function() {
var query = schoolsLayer.createQuery();
return schoolsLayer.queryFeatures(query);
.then(getValues)
.then(addToSelect)
// STATUS2 field of the schools layer
return values;
// the STATUS2 field of the schools layer
if (
item !== ""
values.sort();
schoolTypeSelect.add(option);
return setschoolsDefinitionExpression(schoolTypeSelect.value);
function setschoolsDefinitionExpression(newValue) {
schoolsLayer.definitionExpression = " TypeOfEs_1 = '" + newValue + "'";
if (!schoolsLayer.visible) {
schoolsLayer.visible = true;
return queryForschoolGeometries();
// of the layer
function queryForschoolGeometries() {
var schoolsQuery = schoolsLayer.createQuery();
return schoolsLayer.queryFeatures(schoolsQuery).then(function(response) {
schoolsGeometries = response.features.map(function(feature) {
return schoolsGeometries;
// the school geometries
function createBuffer(schoolPoints) {
var schoolBuffers = geometryEngine.geodesicBuffer(
schoolPoints,
[bufferDistance],
"meters",
true
schoolBuffer = schoolBuffers[0];
if (bufferGraphic) {
bufferGraphic.geometry = schoolBuffer;
} else {
geometry: schoolBuffer,
symbol: {
outline: {
width: 1.5,
style: "none"
// Get the dwelling value set by the user
dwelling = event.value;
if (event.state === "stop") {
createBuffer(schoolsGeometries);
schoolTypeSelect.addEventListener("change", function() {
setschoolsDefinitionExpression(type).then(createBuffer);
// query for brownfields with the specified dwelling
// is clicked
querybrownfields.addEventListener("click", function() {
querybrownfields().then(displayResults);
function querybrownfields() {
var query = brownfieldsLayer.createQuery();
query.where = "dwel >= " + dwelSlider.values[0];
query.geometry = schoolBuffer;
return brownfieldsLayer.queryFeatures(query);
graphic.symbol = {
style: "diamond",
color: "darkorange"
return graphic;
var numbrownfields = features.length;
numbrownfields + " brownfields found";
</script>
</head>
<body>
Select school type:
</div>
Brownfield dwelling:
</div>
</body>
</html>
BlakeTerhune
Checking the console log, you are getting errors in the geometry engine, which would only be in your createBuffer() function. In there, you have a schoolPoints parameter that you need to use in geodesicBuffer(). However, there are a couple places you call createBuffer without any arguments; lines 142 and 245.
