Query and QueryTask Not Returning Results ... Error In Syntax?
1029
14
10-03-2018 10:31 AM
JohnRichardson
New Contributor III
var layerURL = "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer/";            //querys the crimes layer for all burglaries
      var burgresultsLayer = new GraphicsLayer();
            var burgQsym = {                                       //creates the symbol for burglaries query
            type: "simple-marker",
            color: "green",
            style: "triangle",
      /*alert(layerURL);*/
      var qTask = new QueryTask({url : layerURL});
      var burgQuery = new Query();
      burgQuery.returnGeometry = true;
      var fieldBoys = burgQuery.outFields = ["Offense", "Location"];
      /*alert(fieldBoys);*/
      burgQuery.where = "Offense = Burglary";
      qTask.execute(burgQuery).then(function(results) {
            console.log(results.features);
      qTask.executeForCount(burgQuery).then(function(results) {
            console.log(results);
RobertScheitlin__GISP
John,
  That is definitely your issue.
require([
      "esri/Map",
      "esri/views/MapView",
      "esri/widgets/Home",
      "esri/widgets/Search",
      "esri/widgets/BasemapGallery",
      "esri/widgets/Expand",
      "esri/layers/FeatureLayer",
      "esri/layers/ImageryLayer",
      "esri/widgets/LayerList",
      "esri/tasks/QueryTask",
      "esri/tasks/support/Query",
      "esri/layers/GraphicsLayer",
      "dojo/dom",
      "dojo/on",
      "dojo/domReady!"
      ],function(
      Map, MapView, Home, Search, BasemapGallery, Expand, FeatureLayer, ImageryLayer,
      LayerList, QueryTask, Query, GraphicsLayer, dom, on) {
Here is your order fixed
John,
  Your where clause is wrong:
burgQuery.where = "Offense = 'Burglary'";
JohnRichardson
New Contributor III
Thank you ... I edited that code and still no go!
Getting this in console:
dojo.js:19 Uncaught TypeError: qTask.execute is not a function at Map.js:142 at K (dojo.js:18) at dojo.js:19 at E (dojo.js:19) at da (dojo.js:19) at e (dojo.js:21) at HTMLScriptElement.<anonymous> (dojo.js:23)
John,
  OK I did not notice before that your url does not contain a specific layer id at the end of it which is required.
JohnRichardson
New Contributor III
Thank you Robert ... I had noticed that after I posted this code ...
It now reads :
var layerURL = "http://172.20.25.165:6080/arcgis/rest/services/Crime2018/FeatureServer/0";
John,
   If it works now. Don't forget to mark this question as answered by clicking on the "Mark Correct" link on the reply that answered your question.
JohnRichardson
New Contributor III
Not working yet ... thanks for your help!
I will most definitely mark as correct when time comes.
Thanks again.
So what is the error you are getting now then?
JohnRichardson
New Contributor III
Same one
at Map.js:141
at K (dojo.js:18)
at dojo.js:19
at E (dojo.js:19)
at da (dojo.js:19)
at e (dojo.js:21)
John,
  Sounds like your requires are not in sync with their vars then. Can I see more of your code?
