In the API docs, https://developers.arcgis.com/javascript/latest/api-reference/esri-PopupTemplate.html#content, it is mentioned that the pop up template is open using clicks by default. Is there a way to programmatically open a popup template on a graphics layer?
Currently, the only available methods is to open up the pop up on a view.
view.popup.open()
But what I am looking for is, say that I have graphicsLayer initialised as a feature layer
graphicsLayer.graphics.getItemAt(x).popupTemplate.open()
You just use this line of code:
view.popup.open({
features: graphics // array of graphics or a single graphic in an array
view.popup.open({
Hi
Is this possible with a featurelayer content.
For example I'm trying to do this:
var districts = new FeatureLayer({
url: "https:.../server/rest/services/Distritos_SNIT/MapServer/0",
outFields: ["nom_cant", "nom_prov", "nom_distr","cod_prov","cod_distr","cod_canton"],
renderer: renderer,
labelingInfo: [labelClass],
popupTemplate: {
content: "<b>Provincia: </b>{nom_prov} ({cod_prov})<br/> <b>Cantón:</b> {nom_cant} ({cod_canton})<br/> <b>Distrito:</b> {nom_distr} ({cod_distr})",
title: "Ubicación del punto",
popup.open({
title: "Esta es la ubicación de su punto",
feature: [districts],
content: "{nom_prov}"
And I got the following error:
(index):119 [esri.core.Accessor] Accessor#set Assigning an instance of 'esri.layers.FeatureLayer' which is not a subclass of 'esri.Graphic'
Any thought ?
Regards
@DiegoMonge_Chinchilla Just like the error is telling you, You are passing a FeatureLayer to the popups feature property when it is expecting a Graphic or array of Graphics. So something like
const query = new Query();
query.where = "1=1";
query.outSpatialReference = { wkid: 102100 };
query.returnGeometry = true;
query.outFields = [ "nom_prov" ];
districts.queryFeatures(query).then(function(results){
popup.open({
feature: results.features[0],
Would work.
Thanks a lot
I forgot to mention that I'm not a developer, I'm forest engineer so I don't know much about coding.
After a few tries it works with the following adjustments in case someone else needs it:
const query = districts.createQuery();
query.geometry = view.center;
query.spatialRelationship = "intersects";
// query.distance = 2;
// query.units = "meters";
query.returnQueryGeometry = true;
query.outFields = ["nom_prov"];
districts.queryFeatures(query).then(function (results) {
console.log(results)
popup.open({
// feature: results.features[0],
content: results.features[0].attributes.nom_prov
Thanks a lot for your kind help @RobertScheitlin__GISP
