Programing arcgis login online js 4.15
1270
6
06-21-2020 07:57 AM
GenasysEsri
Hello everyone,
I just tried load a customfeatrue layer from my arcgis online account. I did it whitout problems
However every time and open my script there is an esri-identity-form wich ask for user and password (image I added). So, I would like load my personal layers from arcgis online whitout show or view this form, I mean try other way to loading and authentication or just authentication in background process.
Could anyone show me a easy example??
Thanks!!!
Tags (1)
VictorTey
Hi, several thoughts come to mind. Possible options are,
Using the esri proxy, add your login cred to the proxy.
GitHub - Esri/resource-proxy: Proxy files for DotNet, Java and PHP.
Second option would be to manage the token yourself. E.g
  • Get token from rest endpoint
  • Every url request you make, append &token=xxxxx to the url.
GenasysEsri
Hello Victor,
Thanks for your answer.
I have never manage a resource-proxy, the link you attached talks about DotNet, Java and PHP but I am using Javascript. So, I don't understand very well all what it talks about.
Like you see I not have a hight programing level....I was looking for something I can understand, some code or example like:
"This code could help you: you user go here, your password in there..."
Thanks anyway, I keep going study about your answer for finding what I am loking for.
VictorTey
Hi sure. note that the proxy is just another option, without knowing the full context of what you are trying to do
I can expand a bit more on the proxy option however it will still require you to read some of the documentation to see if it suits your requirement.
A proxy essentially acts as a gateway. What that means is that instead of accessing your service url directly like below which requires authentication:
http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson
if you access it via the proxy, it will manage the token for you. (username and password are stored in the proxy config)
http://[yourmachine]/DotNet/proxy.ashx?http://services.arcgisonline.com/ArcGIS/rest/services/?f=pjson
I am going to assume you have access to a web server like microsoft windows IIS. Because it is IIS, look in the DotNet part of the resource-proxy.
resource-proxy/DotNet at master · Esri/resource-proxy · GitHub
Link above provides detail description on how to deploy. Basically it is just copy/paste file, do the config and change your access URL.
Proxy configuration:
resource-proxy/README.md at master · Esri/resource-proxy · GitHub
Note the username and password option
GenasysEsri
Thanks a lot.
For understanding what I am doing:
I use this code for loading a featureLayer from my Arcgis Online Account:
CustomArcgisLayer = new FeatureLayer({
            url: my service url (https://services6.arcgis.com/ ......),
Every time I start my html or application there appear a credential dialog, so, I did this for fill this dialog.
Basically I fill it using javascript
var form_esri_dialog=document.getElementsByClassName("esri-identity-modal esri-identity-modal--open")[0];
if(typeof form_esri_dialog!="undefined"){
            var user= Array.from(document.getElementsByClassName("esri-identity-                form")  [0].querySelectorAll('input[type="text"]'));
              var password=Array.from(document.getElementsByClassName("esri-
              identity- form") [0].querySelectorAll('input[type="password"]'));
               user[0].value="xxxx";
               password[0].value="xxxxx";
               var submit_form= Array.from(document.getElementsByClassName("esri-identity-
               form")[0].querySelectorAll('input[type="submit"]'));
               submit_form[0].click();
I would like not doing this ...I would like do this in a background process or automatically
I will look all the information you gave me,
Very thanks again
VictorTey
So the 2 options I have provide, either one will work.
1 - using the resource-proxy will require 0 coding, you just need to use service url via the proxy as demostrated above.
2 - you can get the token from Generate Token—ArcGIS REST API: Users, groups, and content | ArcGIS for Developers. you need to code this part (Many ways to do this, esri also have a class you can use request | ArcGIS API for JavaScript 4.15 )
Once you have the token, append it to your url.
            url: my service url (https://url.to.your.service/..../whatever&token=fdksfdsfdsa),
GenasysEsri
Very very thanks.
The first option I don't know how could do it ..it is like chinese lenguage for my...I just have a standart arcgis online account..I thought it will be more easy
For the second option the same problem, my url has token and for creating a permanent token (I don't know if your option goes for these way) the example doesn't give to me how write it in javascript
Generate Token
Example1:
https://www.arcgis.com/sharing/rest/generateToken
username=jsmith33
password=myPassword
referer=https://www.arcgis.com
I think it will be in request, but where and how....I don`t see this in request information:
// request GeoJson data from USGS remote server
var url = "https://earthquake.usgs.gov/earthquakes/feed/v1.0/summary/all_hour.geojson";
esriRequest(url, {
   responseType: "json" })
.then(function(response){
// The requested data
var geoJson = response.data; });
So, How could mix both of them??
I don't want to tire you with my questions.
I will continue using the way that works for me now and I understand
I am very grateful for your attention and responses.
You would understand if you didn't answer me, I'm asking a lot from you
