Printtask not working correctly
613
10-03-2020 05:20 AM
NovicaJosifovski
I am trying to use printTask as shown below, but it's not going in the printResult function.
function printImage() {
                        var printTask;
                        var params = new PrintParameters();
                        if (sentScale == 1000) {
                            printTask = new PrintTask('http://10.10.100.50:6080/arcgis/rest/services/karpos/Print_Karpos/GPServer/Export%20Web%20Map');
                            params.map = map;
                        else if (sentScale == 2500) {
                            params.map = map;
                        var template = new PrintTemplate();
                        template.format = 'JPG';
                        template.layout = 'MAP_ONLY';
                        template.preserveScale = false;
                        params.template = template;
                        console.log("params", params)
                        //printTask.execute(params).then(printResult);
                        printTask.execute(params, printResult);
                    // PRINT IMAGE
                    // PRINT RESULT
                    function printResult(evt) {
                        imageUrl = evt.url;
                        setCookie('imageUrl', imageUrl, 1);
                        if (reportType == 1) {
                            printReport();
                        if (reportType == 2) {
                            console.log("reporttype2 start")
                            var printTaskLegend;
                            var printPars = new PrintParameters();
                            printPars.map = map;
                                console.log("reporttype2 1000")
                                printTaskLegend = new PrintTask('http://10.10.100.50:6080/arcgis/rest/services/karpos/Print_Karpos/GPServer/Export%20Web%20Map');
                                console.log("reporttype2 2500")
                            template.layout = 'Print_legend_included';
                            template.preserveScale = true;
                            printPars.template = template;
                            printTaskLegend.execute(printPars, printImageLegend);
                            //printTaskLegend.execute(printPars).then(printImageLegend);
                            console.log("reporttype2 end")
I am printing out the params with console.log in printImage and according to this, I think it ok?
I tried to use both printTask.execute(params).then(printResult); as well as printTask.execute(params, printResult);
but it just does not go into printResult. Anyone has any idea why?
ManishPatel
Hi novica.josifovskigdi-net-esridist
Does the network show the request being passed when you call the print if not then it potentially is unable to reach the printResult function.
What I can suggest you is you can try to modify you code as below:
printTask.execute(params, function(evt){
   //code snippet from your printResult function goes here....
Suspect the print execute is unable to reach to the function.
Cheers,
Manish
Cheers,
Manish
ManishPatel
HiNovica Josifovski,
Just wondering if you managed to fix the code??
Cheers,
Manish
Cheers,
Manish
Noah-Sager
I would try catching a potential error with this format:
printTask.execute(params).then(printResult, printError);
And here it is in action:
https://codepen.io/noash/pen/gOPoxZj?editors=1000
