PrintTask Error with FeatureLayer selection
3285
13
09-10-2012 07:45 PM
ScottDavis3
Using ArcServer 10.1 and JSAPI 3.1. Printtask works when selection of a featurelayer under a feature service is empty. After a selection is made the follow error occurs:
Layer "graphicsLayer0": Failed to create layer from service at http://darkside:6080/arcgis/rest/services/TheAddresser/YorkCounty_SDE/FeatureServer/0. Failed to execute (ExportWebMap). Failed to execute (Export Web Map).
This feature service is secured. Anyone have any ideas? Sample code below.
        var printTask = new esri.tasks.PrintTask(url);
        var templateP = new esri.tasks.PrintTemplate();
        templateP.format = "PDF";
        templateP.layout = "85x11";
        templateP.preserveScale = true;
        template.layoutOptions = { titleText: '', authorText: "ME", scalebarUnit: 'Feet', legendLayers: [] };
        var params = new esri.tasks.PrintParameters();
        params.outSpatialReference = map.spatialReference;
        params.map = map;
        params.template = templateP;
        printTask.execute(params, function (result) {
            window.open(result.url);
            hideWorking();
        }, function (err) {
            errorWin(err, 'printMap');
DonCaviness
New Contributor III
I don't see how this sample will help since none of the services in it use a token? I can get non secure services to work, with a selection or not.
JohnGravois
i was suggesting that you test using our own sample secured service first.  in this application the token is not stored in the application or in a proxy, but rather allows you to authenticate onLoad of the application by passing the credentials user1/user1.
first try printing our sample service, then switch to your own secure service (and after that, your own print service)
DonCaviness
New Contributor III
Having to sign in will not work in a production environment (tokens are a necessity), but apparently there is an issue with the authentication service running in my instance of ArcGIS Server 10.1.  Up until now I haven't had any issues using secure services.  I will case that error down and see if that resolves the issue.
CarlosKrefft
Apparently using printing IWA secured services is no longer supported in 10.4.x because of a vulnerability that existed. So instead of fixing the vulnerability the capability was removed. Wonderful.
