Print Map with InfoTemplate/Popup
1169
12-04-2019 08:21 PM
HenryKo2
Hi, in ArcGIS API for JavaScript v3, is it possible to print a map that has Popup or InfoTemplate being displayed?
For example, in here, popups can show when clicked on the map:
ArcGIS API for JavaScript Sandbox
But how can I print the map including the popup?
I tried the digit-print widget but no luck:
I know that a screen-capture will work, but it won't have the usual things such as legends, titles... etc.
HenryKo2
In the end, I got it working as follows:
  1. All the "popup" / "InfoWindow" was implemented as good old plain HTML DIV elements.
  2. I print these DIV elements using the html2canvas JavaScript library. They are printed as HTML canvas.
  3. I print the map using the standard ArcGIS for Server print API. The map is printed as HTML canvas.
  4. Finally, I "merge" the two printed HTML canvases as one PNG image.
(I could print everything using the html2canvas library but there were some weird issues).
Hope it helps.
Noah-Sager
Ryan Libed‌ wrote a great blog post on this subject using the 4x version of the ArcGIS API for JavaScript:
https://community.esri.com/people/RLibed-esristaff/blog/2018/12/20/screenshots-with-the-arcgis-api-f...
HenryKo2
Hope it helps.
GennadiiPrykhodko
@HenryKo2 - Could you share a code example of your work around? I am trying to do the exact same thing. I have been able print pop-up and the map separately, but I am struggling to merge them together.
HenryKo2
With the other canvas/node, I firstly set the background-color to rgba(254, 254, 254, 1.0) in CSS as a hack to flag that the pixels are meant to be transparent (so the map below it can show through).
When I merge the map and other canvas together, I manually loop through the pixels to find (254, 254, 254, 1.0) pixels and then set these to real transparent pixels (i.e. a value is zero).
mergeCanvases: function(mapCanvas, otherCanvas, mapNode, otherNode) {
    console.log("Merging my canvas on top of map canvas.");
    var srcRect = otherNode.getBoundingClientRect();
    var destRect = mapNode.getBoundingClientRect();
    this.maskContainerBackgroundPixels(otherCanvas, srcRect);
    var mapCanvasContext = mapCanvas.getContext("2d", {
        alpha: true
    // Workaround for different screen resolutions.
    mapCanvasContext.drawImage(otherCanvas, 0, 0, srcRect.width * window.devicePixelRatio, srcRect.height * window.devicePixelRatio, 0, 0, destRect.width, destRect.height);
// Use flag of RGB of (254, 254, 254) to pretend it is "transparent" (so the map below it can show through). Using CSS transparency didn't work.
maskContainerBackgroundPixels: function(otherCanvas, rect) {
    console.log("Masking pixels.");
    var otherContext = otherCanvas.getContext("2d");
    // Manually set the container background background pixels to transparent.
    var canvasImageData = otherContext.getImageData(0, 0, rect.width * window.devicePixelRatio, rect.height * window.devicePixelRatio);
    for (var i = 0; i < canvasImageData.data.length; i += 4) {
        var r = canvasImageData.data[i];
        var g = canvasImageData.data[i + 1];
        var b = canvasImageData.data[i + 2];
        var a = canvasImageData.data[i + 3];
        // We know that rgb(254, 254, 254) need to be set to transparent.
        if (r == 254 && g == 254 && b == 254 && a == 255) {
            canvasImageData.data[i] = r;
            canvasImageData.data[i + 1] = g;
            canvasImageData.data[i + 2] = b;
            canvasImageData.data[i + 3] = 0;
    // The container background is now transparent so the map beneath can show through.
    otherContext.putImageData(canvasImageData, 0, 0);
/* In CSS set the other container background to rgba(254, 254, 254, 1.0) which flags it as 'transparent' pixel. */
.otherContainer {
	/* This is IMPORTANT for printing - these pixels will be masked to transparent when printing. */
	background-color: rgba(254, 254, 254, 1.0);
Hope that helps.
