Potential Bug in Print Task?
1139
6
07-17-2012 06:30 AM
AlanRussian
Let's say you have a map service structured as follows and you want to display and print a map with only "Item 1" visible:
Item Name (ID)
  • Folder 1 (0)
    • Item 1 (1)
    • Item 2 (2)
If you want just "Item 1" (ID = 1) to display, you set the visible layers to [1].  Everything's perfect on the web map.  If you now try to print the map, "Item 1" will display on the printed map; however, it will not display on the legend.
So, I thought maybe I needed to set "Folder 1" as visible in order to get "Item 1" to show up on the legend.  This time, I set the visible items to [0, 1].  The printed map displays just like I wanted with "Item 1" in the map and legend and without "Item 2" displaying; however, "Item 2" displays on the web map.
There appears to be an inconsistency between the JavaScript API and the PrintTask when it comes to handling this situation.  Is this a bug, or am I don't something wrong?
--Alan
JianHuang
Alan,
I agree, will fix it soon. Thanks for letting me know this.
JianHuang
Alan,
You only need to set the visibleLayer as [1]. When creating the print widget, assign the esri.tasks.PrintTemplate.layoutOptions.legend as an array of esri.tasks.LegendLayer objects.
Hope this helps.
AlanRussian
Jian,
I was having the PrintTask do this.  Since I wasn't setting the legendLayers, this would happen automatically.  The documentation says, "If legendLayers is not specified, all operational layers will be present in the legend."
So I was setting the visibleLayers on the layer to [1], and the PrintTask would set the visible layers in the legend to [1].  However, as I was saying in the OP, the visibleLayers parameter for the legend must include the parent layer in order for it to show up on the legend.  That is, I have to tell the legend that the visible layers are [0,1] in this example.
I've come up with code to generate a new list of visible layers that include the parent layer ids.  With help from your post, I then tell the PrintTask to use these IDs.  This solves the issue, but I still think this might be a bug with the legend.
Thanks for your help!
JianHuang
Alan,
MichaelPorter1
I am having a similar problem.  My map has a DynamicMapServiceLayer (id="dynamicLayer") with two group layers - LayerA (id=0) and LayerB (id=4).  LayerA has three subLayers (ids=1,2,3) and LayerB has three subLayers (ids=4,5,6).  In my map layerA and subLayers 1 and 3 are visible and everything else is not so dynamicLayer's visibleLayers attribute equals [0,1,3].
Below is my pseudo code for printing the map:
var legendLayer = new esri.tasks.LegendLayer();
legendLayer.layerId = "dynamicLayer";
legendLayer.subLayerIds = [0,1,3];
var printTemplate = new esri.tasks.PrintTemplate();
printTemplate.format = "JPG";
printTemplate.layout = "Letter ANSI A Landscape";
var layoutOptions = {TitleText: "Test Map",    scalebarUnit: 'Miles', legendLayers: [legendLayer]};
printTemplate.layoutOptions = layoutOptions;
var printParams = new esri.tasks.PrintParameters();
printParams.map = map;
printParams.outSpatialReference = map.spatialReference;
printParams.template = printTemplate;
var printURL = "http://sampleserver6.arcgisonline.com/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export Web Map Task";
var printTask = new esri.tasks.PrintTask(printURL);
printTask.execute(printParams, function(result) {
window.open(result.url + "?timestamp="+(new Date().getTime()));
The problem is that the resulting map will include a legend with layers 1,2, and 3 in it even though they are not visible or in the legendLayer.subLayerIds.  If I change the legendLayer.subLayerIds to [1,3] nothing in the legend shows up.
AdrianMarsden
Same here - before I try another route has anyone got any news about this bug?  Is it likely to be sorted in 3.3?
Cheers
ACM
MichaelParry
I was having this exact problem until I changed a setting in my template mxd. When i checked 'on' the "Only display layers that are checked on in the Table Of Contents" in the legend properties this issue seemed to go away.[ATTACH=CONFIG]19640[/ATTACH]
