POPUP with Subtype
647
07-31-2019 04:17 AM
kawishabbas
Hi
I set subtype on Network filed in arcmap but when i show this field with popup on web application it show coded value instead of description.
Is it possible to show description on popup.
SpikyMS
New Contributor II
Are you using MapImage Layers with SubLayers? I had a similar problem and described it here: https://community.esri.com/message/791957-re-is-it-possible-to-show-coded-values-in-4x-popups. There is a Bug BUG-000115337 which is not yet solved as far as I know.
kawishabbas
I am using Feature Layer
SpikyMS
New Contributor II
I have set up a simple sample here, using a feature layer that also uses coded values: https://codepen.io/dpayk/pen/qemwvy. Maybe you can fork it with you own service to reproduce the behavior.
kawishabbas
Hi
Sorry for late reply......
This code https://codepen.io/dpayk/pen/qemwvy. is not working with my own service
