Popup template - conditional field formatting JS 4.14
868
01-13-2020 12:30 PM
KarstenRank2
I found this question Popup template - conditional title formatting JS 4.14 here in the Community.
Is it also possible to change the color of the field section of the popup template?
 type: "fields",
   fieldInfos: [{
   fieldName: "count",
   label: "name",
   format: {
    digitSeparator: true,
    places: 0
The text of the fieldName "count" should get red if it is < 0 or green if > 0.
Thanks for your help!
Karsten
UndralBatsukh
Hi there,
This sample should show how it can be done.
-Undral
UndralBatsukh
Hi there,
-Undral
KarstenRank2
Thank you Undral!
To create a table should not be a problem after your hint.
Karsten
