i need urgent help.i have my custom page.on page i use bootstrap to create a navigation bar.As you see in the bellow image as highlited in red rectangle.if i click on my scene view it shows a popup with some information.if i use to close popup from cross button.when i press cross button of popup my navigation bar also disappeared.as you see in the other image.
please help me to solve this issue.i am using4.15 arcgis api.i am using scene view.
Thanks once again.waiting for reply.
Nadir,
Sounds like you have a css rule specificity issue. Meaning that you are using some generic css class name like .hidden, .hide , .visible , or the like and esri is using the same class to hide its' popup. Thus when the popup is hidden so is your toolbar. Try making your css rule and class name that hides your navigation tools more specific.
Hi Nadir Hussain,
As Robert Scheitlin, GISP mentioned above, the issue seems very specific to an incorrect CSS implementation. If you could share a working code, then could take a further look and fix it for you.
<!DOCTYPE html>
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<meta charset="utf-8"/>
<meta name="viewport" content="width=device-width, initial-scale=1"/>
<meta http-equiv="X-UA-Compatible" content="IE=edge" />
<meta http-equiv="X-UA-Compatible" content="IE=edge,chrome=1" />
<meta http-equiv="X-UA-Compatible" content="IE=8" />
<meta name="viewport" content="width=device-width, initial-scale=1 maximum-scale=1 minimum-scale=1" />
<link rel="shortcut icon" href="Images/logonew.png" type="image/x-icon" />
<title>123445</title>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.4.1/jquery.min.js"></script>
<script src="https://cdnjs.cloudflare.com/ajax/libs/popper.js/1.14.7/umd/popper.min.js"></script>
<script src="https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js"></script>
<script src="https://maxcdn.bootstrapcdn.com/bootstrap/3.4.1/js/bootstrap.min.js"></script>
<link rel="stylesheet" href="https://js.arcgis.com/4.15/esri/themes/light/main.css" />
<script src="https://js.arcgis.com/4.15/"></script>
<link href="https://ajax.googleapis.com/ajax/libs/jqueryui/1.8/themes/base/jquery-ui.css" rel="stylesheet" type="text/css"/>
<script src="https://ajax.googleapis.com/ajax/libs/jqueryui/1.8/jquery-ui.min.js"></script>
<style>
html, body {
height: 100% !important;
width: 100% !important;
margin: 0px;
padding: 0px;
#menu {
padding: 1em;
.padding-0{
padding-right:0;
padding-left:0;
.navbar {
background-color: #FFF4CB;
height: 80px;
min-height: 80px;
max-height: 80px;
.container-fluid {
background-color: transparent;
padding: 0 !important;
#ViewDiv {
min-height: 100vh;
.navbar-nav .navbar-expand-md .dropdown-menu {
background: border-box;
position: absolute;
#container {
margin: 0 auto;
width: 460px;
padding: 2em;
background: #DCDDDF;
.#topbar {
background: #fff;
padding: 10px;
</style>
<script type="text/javascript">
var map;
var chartCaption;
var flgMugamaat;
var fExt;
var feat;
var activeWidget = null;
var layerList = null;
var strTitle = "";
var graphicsLayer=null;
require(["esri/Map", "esri/views/MapView","esri/layers/MapImageLayer", "esri/views/SceneView", "esri/layers/FeatureLayer", "esri/widgets/BasemapGallery", "esri/widgets/CoordinateConversion", "esri/widgets/Expand",
"esri/widgets/ScaleBar", "esri/widgets/Popup/PopupViewModel", "esri/geometry/Extent", "esri/PopupTemplate", "esri/layers/GraphicsLayer", "esri/widgets/DirectLineMeasurement3D",
"esri/widgets/AreaMeasurement3D","esri/widgets/Search", "esri/Graphic","esri/widgets/Legend","esri/widgets/Home","esri/widgets/LayerList"],
function (Map, MapView,MapImageLayer, SceneView, FeatureLayer, BasemapGallery, CoordinateConversion, Expand, ScaleBar, PopupVM, Extent, PopupTemplate, GraphicsLayer, DirectLineMeasurement3D,
AreaMeasurement3D,Search, Graphic,Legend,Home,LayerList) {
graphicsLayer = new GraphicsLayer();
//var layer = new MapImageLayer();
var Lyr1PopupTemplate = {
title: "مجمعات_الأنشطة_التعدينية المعتمدة", content: [{
type: "fields",
fieldInfos: [{ fieldName: "أسم_المجمع", label: "أسم المجمع", visible: true }, { fieldName: "أسم_الموقع", label: "أسم الموقع", visible: true }]
var Lyr2PopupTemplate = {
title: "مجمعات_الأنشطة_التعدينية_المقترحة", content: [{
type: "fields",
fieldInfos: [{ fieldName: "تصنيف_خام", label: "تصنيف_خام", visible: true }, { fieldName: "رقم_المجمع", label: "رقم المجمع", visible: true }]
var Lyr3PopupTemplate = {
title: "موقع إحتياطى تعدينى", content: [{
type: "fields",
fieldInfos: [{ fieldName: "اسم_الموقع", label: "اسم الموقع", visible: true }, { fieldName: "اسم_المجمع", label: "اسم المجمع", visible: true }]
var Lyr4PopupTemplate = {
title: "الحدود الإدارية", content: [{
type: "fields",
fieldInfos: [{ fieldName: "Aname", label: "Arabic Name", visible: true }, { fieldName: "Ename", label: "English Name", visible: true }]
var llist= new MapImageLayer({url:"",title: "Census Demographics",
sublayers: [
title: "مشاريع رخص محاجر مواد بناء",
visible: true,
source: { mapLayerId: 0 }
title: "مشاريع رخص التعدين",
visible: true,
source: { mapLayerId: 1}
title: "مشاريع رخص محاجر مواد خام",
visible: true,
// points to the block groups layer
source: { mapLayerId: 2}
title: "مشاريع رخص المناجم الصغيرة",
visible: true,
source: { mapLayerId: 3}
title: "مشاريع رخص الكشف",
visible: true,
source: { mapLayerId:4 }
title: "رخص محاجر مواد بناء السارية المفعول",
visible: true,
source: { mapLayerId:5 }
title: "رخص التعدين السارية المفعول",
visible: true,
source: { mapLayerId:6}
title: "رخص محاجر مواد خام السارية المفعول",
visible: true,
source: { mapLayerId:7}
title: "رخص المناجم الصغيرة السارية المفعول",
visible: true,
source: { mapLayerId:8}
title: "رخص الكشف السارية المفعول",
visible: true,
source: { mapLayerId:9}
title: "تجديد رخص محاجر مواد بناء",
visible: true,
source: { mapLayerId:10}
title: "تجديد رخص التعدين",
visible: true,
source: { mapLayerId:11}
title: "تجديد رخص محاجر مواد خام",
visible: true,
source: { mapLayerId:12}
title: "تجديد رخص المناجم الصغيرة",
visible: true,
source: { mapLayerId:13}
title: "تجديد رخص الكشف",
visible: true,
source: { mapLayerId:14}
title: "رخص محاجر مواد بناء الصادرة المبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:15}
title: "رخص التعدين الصادرة المبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:16}
title: "رخص محاجر مواد خام الصادرة مبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:17}
title: "رخص المناجم الصغيرة الصادرة المبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:18}
title: "رخص الكشف الصادرة المبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:19}
title: "رخص حقوق الإرتفاق الصادرة المبلغ عنها بالإنتهاء",
visible: true,
source: { mapLayerId:20}
title: "رخص محاجر مواد بناء المنتهية",
visible: true,
source: { mapLayerId:21}
title: "رخص التعدين المنتهية",
visible: true,
source: { mapLayerId:22}
title: "رخص محاجر مواد خام المنتهية",
visible: true,
source: { mapLayerId:23}
title: "رخص المناجم الصغيرة المنتهية",
visible: true,
source: { mapLayerId:24}
title: "رخص الكشف المنتهية",
visible: true,
source: { mapLayerId: 25 }
title: "مجمعات الأنشطة التعدينية المعتمدة",
visible: true,
source: { mapLayerId: 26 },
popupEnabled: true, popupTemplate: Lyr1PopupTemplate
title: "مجمعات الأنشطة التعدينية المقترحة",
visible: true,
source: { mapLayerId: 27 },
popupEnabled: true, popupTemplate: Lyr2PopupTemplate
visible: true,
source: { mapLayerId: 28 },
popupEnabled: true, popupTemplate: Lyr3PopupTemplate
visible: true,
source: { mapLayerId: 29},
popupEnabled: true, popupTemplate: Lyr4PopupTemplate
map = new Map({ basemap: "satellite",layers: [llist]});
var ext = new Extent({ xmin: 34.569673375000036, ymin: 16.37983382100009, xmax: 55.666503900000066, ymax: 32.16033986800005, spatialReference: { wkid: 4326 } });
var view = new SceneView({
container: "viewDiv",
map: map,
//camera: { position: {x:43.951098,y:24.304549}, tilt: 0 },
//center: [43.951098, 24.304549],
viewingMode: "global",
/*popup: {
autoOpenEnabled: true,
dockEnabled: true,
dockOptions: {
// dock popup at bottom-right side of view
buttonEnabled: true,
breakpoint: true,
position: "bottom-left"
//Sets the zoom LOD to 13
zoom: 6,
// Create new instance of the Measurement widget
document.getElementById("distanceButton")
.addEventListener("click", function () {
setActiveWidget(null);
if (!this.classList.contains("active")) {
setActiveWidget("distance");
} else {
setActiveButton(null);
document.getElementById("areaButton")
setActiveWidget("area");
} else {
function setActiveWidget(type) {
switch (type) {
case "distance":
activeWidget = new DirectLineMeasurement3D({
view: view
// skip the initial 'new measurement' button
activeWidget.viewModel.newMeasurement();
view.ui.add(activeWidget, "top-right");
setActiveButton(document.getElementById("distanceButton"));
break;
case "area":
activeWidget = new AreaMeasurement3D({
view: view
setActiveButton(document.getElementById("areaButton"));
break;
case null:
if (activeWidget) {
view.ui.remove(activeWidget);
activeWidget.destroy();
break;
function setActiveButton(selectedButton) {
// focus the view to activate keyboard shortcuts for sketching
view.focus();
var elements = document.getElementsByClassName("active");
for (var i = 0; i < elements.length; i++) {
elements.classList.remove("active");
if (selectedButton) {
selectedButton.classList.add("active");
* Add feature layer
var pt = ext.cneter;
// Carbon storage of trees in Warren Wilson College.
var featureLayer = new FeatureLayer({
url:
"https://gis.dmmr.gov.sa/arcgis/rest/services/DMMR/Mop_Main_App_3_june/FeatureServer/29"
map.add(featureLayer);
//featureLayer.when(function () {
// //featureLayer.definitionExpression = createDefinitionExpression("");
// zoomToLayer(featureLayer);
view.goTo({
position: {
x: 43.951098,
y: 24.304549,
z: 5000000,
spatialReference: {
wkid: 4326
heading: 0,
tilt: 0
speedFactor: 0.1,
easing: "out-quint"
featureLayer.load().then(function() {
// Set the view extent to the data extent
//view.extent = layer.fullExtent;
featureLayer.popupTemplate = featureLayer.createPopupTemplate();
var zoomOutAction = {// This text is displayed as a tooltip
title: "Zoom out",
// The ID by which to reference the action in the event handler
// Sets the icon font used to style the action button
className: "esri-icon-zoom-out-magnifying-glass"
view.popup.viewModel.actions.push(zoomOutAction);
// The function to execute when the zoom-out action is clicked
function zoomOut() {
var new_ext = new Extent({ xmin: fExt.xmin, ymin: fExt.ymin, xmax: fExt.xmax, ymax: fExt.ymax, spatialReference: { wkid: 4326 }});
//view.goTo(fExt, { speedFactor: 0.1, easing: "out-quint" });
view.goTo(new_ext);
// This event fires for each click on any action
view.popup.viewModel.on("trigger-action", function(event){
// If the zoom-out action is clicked, fire the zoomOut() function
if(event.action.id === "zoom-out"){
zoomOut();
view.when(function() {
layerList = new LayerList({
view: view,
listItemCreatedFunction: function(event) {
const item = event.item;
if (item.layer.type == "group") {
// don't show legend twice
item.panel = {
content: "legend",
open: true
// Add widget to the top right corner of the view
var layerListExpand = new Expand({
view: view,
content: layerList,
expandIconClass: "esri-icon-layer-list1",
group: "top-right"
view.ui.add([layerListExpand], "top-right");
var legend = new Legend({view: view,
style: "classic" // other styles include 'classic'
//view.ui.add(legend, "bottom-left");
var basemapGallery = new BasemapGallery({ view: view });
// Add the widget to the top-right corner of the view
var bgExpand = new Expand({
view: view,
content: basemapGallery,
expandIconClass: "esri-icon-basemap",
expandTooltip: "Basemap",
group: "top-right"
// close the expand whenever a basemap is selected
basemapGallery.watch("activeBasemap", function () {
var mobileSize =
view.heightBreakpoint === "xsmall" ||
view.widthBreakpoint === "xsmall";
if (mobileSize) {
bgExpand.collapse();
//view.ui.add(basemapGallery, {position: "top-right"});
//view.ui.add(bgExpand, "top-right");
var ccWidget = new CoordinateConversion({view: view});
var scaleBar = new ScaleBar({
view: view,
unit: "dual" // The scale bar displays both metric and non-metric units.
var measureExpand = new Expand({
view: view,
content: topbar,
expandIconClass: "esri-icon-measure-line",
expandTooltip: "measement",
group: "top-right"
var ccExpand= new Expand({
view: view,
content: ccWidget,
expandIconClass: "esri-icon-applications",
group: "top-right"
var searchExpand= new Expand({
view: view,
content: searchWidget,
expandIconClass: "esri-icon-search",
group: "top-right"
var legendExpand = new Expand({
view: view,
content: legend,
expandIconClass: "esri-icon-default-action",
group: "top-right"
var menuExpand = new Expand({
view: view,
expandIconClass: "esri-icon-menu",
content: document.getElementById("menu"),
expanded: false,
group: "top-right"
//view.ui.add("topbar", "top-right");
view.ui.add([bgExpand, measureExpand,ccExpand,searchExpand,legendExpand,menuExpand], "top-right");
//view.ui.add([ccExpand],"bottom-right");
/*view.ui.add([
component: bgExpand,
position: "top-right",
index: 0
component: ccWidget,
position: "bottom-right",
index: 1
component: scaleBar,
position: "bottom-left",
index: 2
//var vp = new Viewpoint({targetGeometry: geom.extent});
//home.viewpoint = vp;
var homeBtn = new Home({view: view});
// Add the home button to the top left corner of the view
view.ui.add(homeBtn, "top-left");
homeBtn.goToOverride = function (view, goToParams) {
//alert("gp");
graphicsLayer.removeAll();
return view.goTo({
position: {
x: 43.951098,
y: 24.104549,
z: 5000000,
spatialReference: {
wkid: 4326
heading: 0,
tilt: 0
speedFactor: 0.1,
easing: "out-quint"
function setView(){
view.goTo({
position: {
x: 43.951098,
y: 24.104549,
z: 5000000,
spatialReference: {
wkid: 4326
heading: 0,
tilt: 0
speedFactor: 0.1,
easing: "out-quint"
function zoomToLayer(layer) {
return layer.queryExtent().then(function (response) {
view.goTo(response.extent).catch(function (error) {
if (error.name != "AbortError") {
console.error(error);
function dynamicPanel() {
$('#mainRow').css('direction', 'rtl');
$('#MenusTools').css('direction', 'ltr');
//$("#mainRow").append("<div id=left class='row mt-1'></div>");
$('#left').empty();
$('#left').removeClass('col-lg-0');
$('#left').removeClass('col-xl-0');
$('#left').removeClass('col-sm-0');
$('#left').removeClass('col-md-0');
$('#left').addClass('col-lg-6');
$('#left').addClass('col-xl-6');
$('#left').addClass('col-sm-6');
$('#left').addClass('col-md-6');
$('#left').addClass('padding-0');
$('#left').css('background-color','#14197A');
$('#left').css('height', 'inherit');
$('#left').css('width', '100%');
$('#left').css('float', 'left !important');
$('#right').removeClass('col-lg-12');
$('#right').removeClass('col-xl-12');
$('#right').removeClass('col-sm-12');
$('#right').removeClass('col-md-12');
$('#right').addClass('col-lg-6');
$('#right').addClass('col-xl-6');
$('#right').addClass('col-sm-6');
$('#right').addClass('col-md-6');
$('#right').addClass('padding-0');
$('#right').css('height', '100%');
$('#right').css('width', '100%');
$('#right').css('float', 'right !important');
//*********************Area Div**********************************************//
$("#divArea").append("<div id=divArea1 class='col col-lg-12 col-xl-12 col-md-12 col-lg-12' ></div>");
$("#divArea1").append("<div id=divArea2 class='row'> </div>");
$("#divArea2").append("<div id=divArea21 class='col col-lg-6 col-xl-6 col-md-6 col-lg-6' ></div>");
$("#divArea2").append("<div id=divArea22 class='col col-lg-6 col-xl-6 col-md-6 col-lg-6' ></div>");
$("#divArea21").append("<div id=divArea211 class='row' ></div>");
$("#divArea21").css('margin-right', '8px');
$("#divArea21").css('border-right', 'solid 2px grey');
$("#divArea21").css('border-top', 'solid 2px grey');
$("#divArea21").css('border-bottom', 'solid 2px grey');
$('#divArea211').css('direction', 'ltr');
$('#divArea211').css('margin-left', '60%');
$('#divArea211').css('font-weight', 'bold');
$('#divArea211').css('font-size', 'large');
$('#divArea211').css('font-family', 'DroidArabicKufiRegular');
$('#divArea211').css('color', '#14197A');
$("#divArea211").append("<div><label id=lblCounter ></label></div>");
////*********************Area Div**********************************************//
$("#divArea22").append("<div id=divArea221 class='row' ></div>");
$("#divArea22").css('margin-right', '-27px');
$("#divArea22").css('border-left', 'solid 2px grey');
$("#divArea22").css('border-top', 'solid 2px grey');
$("#divArea22").css('border-bottom', 'solid 2px grey');
$('#divArea221').css('direction', 'ltr');
$('#divArea221').css('margin-left', '0%');
$('#divArea221').css('font-weight', 'bold');
$('#divArea221').css('font-size', 'large');
$('#divArea221').css('font-family', 'DroidArabicKufiRegular');
$('#divArea221').css('color', '#14197A');
$("#divArea221").append("<div><label id=lblArea ></label></div>");
//*********************Chart Div**********************************************//
$("#left").append("<div id=divChart class='row mt-1'></div>");
$('#divChart').css('height', '50%');
$("#divChart").append("<div id=divChart1 class='col col-lg-12 col-xl-12 col-md-12 col-lg-12' ></div>");
$("#divChart1").append("<div id=barChartContainer class='row'></div>");
$('#barChartContainer').css('height', '100%');
$('#barChartContainer').css('width', '100%');
$('#barChartContainer').css('margin-right', '-5px');
$('#barChartContainer').css('border', '2px solid #ced4da');
$("#left").append("<div id=divChart2 class='row mt-1'></div>");
$('#divChart2').css('height', '40%');
$("#divChart2").append("<div id=divChart21 class='col col-lg-12 col-xl-12 col-md-12 col-lg-12' ></div>");
$("#divChart21").append("<div id=barChartContainer1 class='row'></div>");
$('#barChartContainer1').css('height', '100%');
$('#barChartContainer1').css('width', '100%');
$('#barChartContainer1').css('margin-right', '-5px');
$('#barChartContainer1').css('border', '2px solid #ced4da');
$('#SearchButton1').bind('click', function () {
var progressBarVal = 100;
try {
$('#pBar').css('visibility', 'visible');
$('#pBar').css('display', 'block');
chartCaption = "الوضع الراهن لرخص محاجر مواد البناء";
setTimeout(function () {
$('#pBar').css('visibility', 'hidden');
dynamicPanel();
setView();
var featureLayer1 = new FeatureLayer({
url: "",
outFields: ["*"],
featureLayer1.queryFeatures().then(function (results) {
// prints an array of all the features in the service to the console
console.log(results.features);
addGraphics(results,"رخص محاجر مواد البناء");
PageMethods.getTotalProjects("4", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("4", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
txt = "There was an error on this page.\n\n";
txt += "Error description: " + err.message + "\n\n";
txt += "Click OK to continue.\n\n";
alert(txt);
$('#SearchButton2').bind('click', function () {
try {
chartCaption = "الوضع الراهن لرخص المناجم الصغيرة";
dynamicPanel();
setView();
url: "",
outFields: ["*"]
//map.add(featureLayer1);
addGraphics(results, "رخص المناجم الصغيرة");
PageMethods.getTotalProjects("1", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("1", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
$('#SearchButton3').bind('click', function () {
try {
chartCaption = "الوضع الراهن لرخص التعدين";
dynamicPanel();
setView();
url: "",
outFields: ["*"]
addGraphics(results, "رخص التعدين السارية المفعول");
PageMethods.getTotalProjects("3", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("3", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
$('#SearchButton4').bind('click', function () {
try {
chartCaption = "الوضع الراهن لرخص محاجر مواد خام";
dynamicPanel();
setView();
url: "",
outFields: ["*"]
addGraphics(results, "رخص محاجر مواد خام السارية المفعول");
PageMethods.getTotalProjects("2", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("2", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
$('#SearchButton5').bind('click', function () {
try {
chartCaption = "الوضع الراهن لرخص الكشف";
dynamicPanel();
setView();
url: "",
outFields: ["*"]
addGraphics(results, "رخص الكشف السارية المفعول");
PageMethods.getTotalProjects("5", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("5", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
$('#SearchButton6').bind('click', function () {
try {
chartCaption = "الوضع الراهن الاحتياطي التعدينى";
dynamicPanel();
setView();
url: "",
outFields: ["*"]
addGraphics(results, "مجمعات الأنشطة التعدينية المعتمدة");
chartCaption = "الوضع الراهن المجمعات التعدينية",
PageMethods.getTotalProjects("6", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("6", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
$('#SearchButton7').bind('click', function () {
try {
dynamicPanel();
setView();
url: "",
outFields: ["*"]
addGraphics(results, "موقع إحتياطى تعدينى");
PageMethods.getTotalProjects("7", OnSuccessTaadeen, OnError);
PageMethods.getTotalMinerals("7", OnSuccessMinerals, OnError);
}, 5000);
catch (err) {
alert(txt);
function addGraphics(result,Title) {
var strContents;
var strHeader = "";
var template = null;
result.features.forEach(
function(feature){
var point1 = { type: "point", x: feature.geometry.extent.center.x, y: feature.geometry.extent.center.y};
strHeader = "<thead><tr><th align=center bgcolor=#FFF4CB><font-weight=bold><font color=#14197A><font-size=large>Values</th><th align=center bgcolor=#FFF4CB><font color=#14197A><font-size=large>Name</th></tr></thead><tbody>";
if(Title!=="موقع إحتياطى تعدينى" && Title!=="مجمعات الأنشطة التعدينية المعتمدة"){
//alert(Title);
strContents = setContents(feature);
strHeader = "<font size=2 face=Courier New><table width=100% border='2px solid black' direction='initial' >" + strHeader + strContents + "</tbody>" + "</table></font>";
template = new PopupTemplate({ title: Title, content: strHeader, actions: [zoomOutAction], overwriteActions: true });
strHeader="";
var g = new Graphic({
geometry: point1,
attributes: { FExtent: feature.geometry.extent, feature: feature },//feature.attributes,
symbol: { type: "simple-marker", color: [0, 0, 0], outline: { width: 2, color: [0, 255, 255], }, size: "10px" },
popupTemplate: template
//popupTemplate: { title: Title, actions: [ { id: "moadBina",
//image:"https://developers.arcgis.com/javascript/latest/sample-code/popup-custom-action/live/beer.png",
//title: "Brewery Info"
graphicsLayer.add(g);
map.add(graphicsLayer);
function setContents(feat){
var strContent = "";
//if (idResult.layerId != 5) {
// dblArea1 = feat.feature.attributes.Area_Zone / 1000000;
// dblArea1 = dblArea1.toFixed(3);
//else {
var dblArea1 = feat.attributes.Area_Zone;
strContent = "";
strContent = "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + feat.attributes.اسم_الشركة + "</td>";
strContent = strContent + "<td align=center style=color:#14197A>" + "اسم الشركة" + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + feat.attributes.الامارة;
strContent = strContent + "<td align=center style=color:#14197A>" + "الامارة" + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + feat.attributes.الموقع;
strContent = strContent + "<td align=center style=color:#14197A>" + "الموقع" + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + feat.attributes.نوع_الخام;
strContent = strContent + "<td align=center style=color:#14197A>" + "نوع الخام" + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + feat.attributes.رقم_القرار;
strContent = strContent + "<td align=center style=color:#14197A>" + "رقم القرار " + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + convertDateFormat(feat.attributes.تاريخ_القرار);
strContent = strContent + "<td align=center style=color:#14197A>" + "تاريخ القرار " + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + convertDateFormat(feat.attributes.الانتهاء);
strContent = strContent + "<td align=center style=color:#14197A>" + "تاريخ الانتهاء " + "</td>" + "</tr>";
strContent = strContent + "<tr align=center bgcolor=#FFF4CB color=#14197A>" + "<td align=center style=color:#14197A>" + dblArea1;// feat.feature.attributes.Area_Zone;
strContent = strContent + "<td align=center style=color:#14197A>" + "المساحة" + "</td>" + "</tr>";
//if ((idResult.layerId == 6) || (idResult.layerId == 7) || (idResult.layerId == 9)) {
// strLyr = getPath(idResult.layerId, feat.feature.attributes.OBJECTID_12, "");
// strContent = strContent + "<tr>" + "<td align=center colspan=2 font-size: large;font-weight: 600;color:blue;font-family: 'Helvetica Neue',Helvetica,Arial,sans-serif;>" + "<a href=" + strLyr + ">المزيد من المعلومات</a> " + "</td>"
//else {
strLyr = getPath(5, feat.attributes.OBJECTID_1, "");
strContent = strContent + "<tr align=center bgcolor=#FFF4CB>" + "<td align=center colspan=2 font-size: large;font-weight: 600;color:blue;font-family: 'Helvetica Neue',Helvetica,Arial,sans-serif;>" + "<a href=" + strLyr + ">المزيد من المعلومات</a> " + "</td>"
return strContent;
/* view.on("click", function(screenPoint) {
view.hitTest(screenPoint)
.then(function(response){
// do something with the result graphic
var graphic = response.results[0].graphic;
feat=graphic.attributes.feature;
fExt=graphic.attributes.FExtent;
view.popup.open({location: screenPoint, features: [graphic]});
//view.when(function () {
// alert("Hello graphic");
// // Watch for when features are selected
// view.popup.watch("selectedFeature", function (graphic) {
// if (graphic) {
// // Set the action's visible property to true if the 'website' field value is not null, otherwise set it to false
// var graphicTemplate = graphic.getEffectivePopupTemplate();
/*view.popup.watch("selectedFeature", function (graphic) {
alert("Hello");
if (graphic) {
graphicTemplate.actions.items[0].visible = graphic.attributes.website ? true : false;
var pointGraphic = new Graphic({
symbol: {
type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
color: [0, 0, 139],
outline: {
color: [255, 255, 255],
width: 1.5
function queryFeatures(screenPoint) {
const point = view.toMap(screenPoint);
featureLayer.queryFeatures({
geometry: point,
// distance and units will be null if basic query selected
distance: null,
units: null,
spatialRelationship: "intersects",
returnGeometry: false,
outFields: ["*"]
.then(function (featureSet) {
// set graphic location to mouse pointer and add to mapview
pointGraphic.geometry = point;
view.graphics.add(pointGraphic);
// open popup of query result
view.popup.open({
features: featureSet.features,
featureMenuOpen: true
// Call the appropriate DistanceMeasurement2D or DirectLineMeasurement3D
function distanceMeasurement() {
const type = activeView.type;
//measurement.activeTool = type.toUpperCase() === "2D" ? "distance" : "direct-line";
distanceButton.classList.add("active");
areaButton.classList.remove("active");
// Call the appropriate AreaMeasurement2D or AreaMeasurement3D
function areaMeasurement() {
measurement.activeTool = "area";
distanceButton.classList.remove("active");
areaButton.classList.add("active");
// Clears all measurements
function clearMeasurements() {
measurement.clear();
</script>
</head>
<body style="overflow-x:hidden;overflow-y:hidden;">
<div style="border:solid 5px #D5A538">
<nav class="navbar navbar-dark navbar-expand-md justify-content-between" style=" border:5px solid #14197A">
<div class="container-fluid" >
<div class="navbar-collapse collapse dual-nav w-50 order-1 order-md-0">
<a href="#" class="navbar-brand">
<img src="Images/leftLogo.png" width="65" alt="" class="d-inline-block align-middle " />
</a>
</div>
<a href="" class="navbar-brand mx-auto d-block text-center" style="color:black; font-family: 'DroidArabicKufiRegular';font-weight: normal;font-style: normal; font-size:xx-large;font-weight:900;color:#14197A">بوابة المعلومات التعدينية</a>
<div class="navbar-collapse collapse dual-nav w-50 order-2">
<ul class="navbar-nav ml-auto">
<li class="nav-item dropdown">
<div class="dropdown">
<button class="btn btn-primary dropdown-toggle" type="button" id="dropdownMenu1" data-toggle="dropdown" style="background-color:transparent;border:none;"
aria-haspopup="true" aria-expanded="false"><img src="Images/Menu3.png" style="margin-top:32px;margin-right:-5px" />
</button>
<div class="dropdown-menu dropdown-primary" style="background-color:#FFF4CB;">
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="Main.aspx">رخص محاجر مواد البناء</a>
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="ManajimAlsageera/Masharia.aspx">رخص المناجم الصغيرة</a>
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="RukhsaTaadeen/TaadeenMasharia.aspx">رخص التعدين</a>
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="MoadKhaam/KhaamMasharia.aspx">رخص محاجر مواد خام</a>
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="Kashf/KashfMasharia.aspx">رخص الكشف</a>
<a class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular" href="Magamaat/Moatmada.aspx">المجمعات التعدينية</a>
</div>
</div>
</li>
<li class="nav-item" >
<a class="nav-link" id="logout" href="Default.aspx">
<img src="Images/logout3.png" style="margin-top:30px" /> </a>
</li>
<li class="nav-item">
<a class="nav-link" href="Home.aspx">
<img src="Images/Home3.png" style="margin-top:30px"/>
</a>
</li>
<a class="nav-link" href="">
<img src="Images/newlogo2.png" width="170" alt="" class="d-inline-block align-middle mr-2 mt-1" />
</a>
</li>
</ul>
</div>
</div>
</nav>
</div>
<div class="container-fluid">
<div id="mainRow" class="row">
<div id="right" class="col col-sm-12 col-md-12 col-lg-12 col-xl-12">
<div id="viewDiv" style="left: 0px; right: 0px; bottom: 0px; top: 0px; height: 100vh">
</div>
<div id="topbar">
<button class="action-button esri-icon-measure-line" id="distanceButton" type="button" title="Measure distance between two points"></button>
<button class="action-button esri-icon-measure-area" id="areaButton" type="button" title="Measure area" ></button>
</div>
<div id="menu" class="esri-widget" style="border:solid 5px #14197A;background-color:#D5A538">
<a id="SearchButton1" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">رخص محاجر مواد البناء</a>
<a id="SearchButton2" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">رخص المناجم الصغيرة</a>
<a id="SearchButton3" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">رخص التعدين</a>
<a id="SearchButton4" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">رخص محاجر مواد خام</a>
<a id="SearchButton5" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">رخص الكشف</a>
<a id="SearchButton6" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">المجمعات التعدينية</a>
<a id="SearchButton7" href="#" class="dropdown-item myLabel" style="background-color:#FFF4CB;color:#14197A;font-family:DroidArabicKufiRegular;border:2px solid #14197A">الاحتياطي التعدينى</a>
</div>
</div>
<div id="left" class="col col-sm-0 col-md-0 col-lg-0 col-xl-0">
</div>
</div>
</div>
<div id="pBar" class = "progress" style="height:100px; width:100px;visibility:hidden;top:50%;left:45%;z-index:100;position:fixed;background-color:transparent;">
<img src="Images/loading.gif" height="100" width="100" />
</div>
<form id="Form1" runat="server">
<asp:ScriptManager ID="ScriptManager1" EnablePartialRendering="true" EnablePageMethods="true" EnableScriptGlobalization="true" runat="server" />
</form>
</body>
</html>
this is my code.here i remove url of my image service.pls check this.
