Popup.open() function used to highlight feature have an unstable error @ ArcGIS for JavaScript 4.20
1180
08-23-2021 09:18 AM
ForyondChao
New Contributor II
My Server is ArcGIS Server 10.2,I published the mapping service using ArcMap 10.2 , and the layers data from database (SQL Server 2019) directly.  When I don't register the database, publishing maps automatically copies the data from the database to the server ,  a new unique field called OBJECTID is automatically added to the layer properties table ,  Popup is right now.
but, when I register the database to ArcGIS Server,  I  call the  popup.open()  function to show a feature's property,  some unfixed errors have occurred.   I noticed that the new unique field added by ArcGIS changed from OBJECTID to ESRI_OID,  I modified the codes, but, error still.  The error appeared is that when I popup a feature, the highlight geometry is part of the target feature or sometime is other feature. something like this:
but now the geometry obtained from server is correct, there are 6 points for the geometry.
Here is my code.
Could you please tell me how to fix this bug  or  possible reasons? Looking forward to your reply, Thanks!
ForyondChao
New Contributor II
I used a simple method to get around this problem
1. Turn popUp's built-in highlighting off.
const view = new MapView({
 popup:{highlightEnabled:false}
2. Use the default graphic in the View to add color for geometry every time it is selected.
sym= new {
type:"simple-fill",
color:[0,255,255,0.5],
style:"solid",
outline:{color:[255,255,0], width:1, style:"solid"}
view.graphics.add(new Graphic({geometry:geometry, symbol:sym}));
Now I can achieve my goal, thanks to the forum!
ForyondChao
New Contributor II
Hi  GarryGoldberg!
How do you to solve the problem ?
ForyondChao
New Contributor II
sym= new {
type:"simple-fill",
style:"solid",
kukiyang
this is awesome, try it out! https://word-unscrambler.io
