Popup in FeatureLayer does not work with Internet Explorer 11
1172
02-07-2017 10:54 AM
ManuelGranados
I am creating a FeatureLayer with client side graphics and attaching a popup to the layer, but the popup does not display when using Internet Explorer 11; with Chrome there is no problem. I checked the sample code in the ESRI web site (https://developers.arcgis.com/javascript/latest/sample-code/sandbox/index.html?sample=layers-feature...) and the problem persists. However, if I change the version in the sandbox of the sample code to 4.1, it works in IE 11 (the popup is displayed). Is this a problem with version 4.2 and IE11? Is there a quick solution?
Thanks!
MikeDolbow
Did you ever figure this out? I am working with 4.14 and the first time after a search the popup appears with no content. The second time through it works as expected.
StefanUseldinger
Occasional Contributor II
Doesn't work for me either in 4.15 using Internet Explorer 11.
I receive the message:
SCRIPT438: Object doesn't support property or method 'forEach'
Feature.js (103,41)
The Popup does not load properly.
Test page: here (Esri NL data, hosted on ArcGIS Online)  or here (my data, hosted on my Portal)
The problem always shows up, if I set Display = A description from one field
StefanUseldinger
Here's an example using a sandbox: https://jsfiddle.net/z6jLr2op/2/embedded/result,html
The problem occurs when using:
content: [{
    type: "text",
    text: "{naam}"
Instead, the following code works:
content: "{naam}"
According to the doc, both PopupTemplates should work.
StefanUseldinger
This is now a BUG-000130719
