Popup does not work after elevation widget
1720
8
05-04-2021 02:45 AM
Vakhtang_Zubiashvili
Occasional Contributor III
Hello again,
I have issue: I have mapView and I use elevation profile widget on it, it works perfect, shows elevation data as shoudl, but after it I can't use Popup, I click on map, but nothing happens. What might be cause?
thanks,
KenBuja
MVP Esteemed Contributor
I'm wondering if this is a bug. I get the same results when adding the widget to the PopupTemplate sample.
<html>
<head>
  <meta charset="utf-8" />
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <title>Intro to PopupTemplate | Sample | ArcGIS API for JavaScript 4.19</title>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <link rel="stylesheet" href="https://js.arcgis.com/4.19/esri/themes/light/main.css" />
  <script src="https://js.arcgis.com/4.19/"></script>
  <script>
    require([
      "esri/Map",
      "esri/layers/FeatureLayer",
      "esri/views/MapView",
      "esri/widgets/Legend",
      "esri/widgets/ElevationProfile"
    ], (Map, FeatureLayer, MapView, Legend, ElevationProfile) => {
      // Create the map
      const map = new Map({
        basemap: "gray-vector",
        ground: 'world-elevation'
      // Create the MapView
      const view = new MapView({
        container: "viewDiv",
        map: map,
        center: [-73.95, 40.702],
        zoom: 10
      view.ui.add(new Legend({ view: view }), "bottom-left");
       * The PopupTemplate content is the text that appears inside the
       * popup. {fieldName} can be used to reference the value of an
       * attribute of the selected feature. HTML elements can be used
       * to provide structure and styles within the content. The
       * fieldInfos property is an array of objects (each object representing
       * a field) that is use to format number fields and customize field
       * aliases in the popup and legend.
      const template = {
        // autocasts as new PopupTemplate()
        title: "{NAME} in {COUNTY}",
        content: [
            // It is also possible to set the fieldInfos outside of the content
            // directly in the popupTemplate. If no fieldInfos is specifically set
            // in the content, it defaults to whatever may be set within the popupTemplate.
            type: "fields",
            fieldInfos: [
                fieldName: "B12001_calc_pctMarriedE",
                label: "Married %"
                fieldName: "B12001_calc_numMarriedE",
                label: "People Married",
                format: {
                  digitSeparator: true,
                  places: 0
                fieldName: "B12001_calc_numNeverE",
                label: "People that Never Married",
                format: {
                  places: 0
                fieldName: "B12001_calc_numDivorcedE",
                label: "People Divorced",
                format: {
                  places: 0
      // Reference the popupTemplate instance in the
      // popupTemplate property of FeatureLayer
      const featureLayer = new FeatureLayer({
        url: "https://services.arcgis.com/P3ePLMYs2RVChkJx/ArcGIS/rest/services/ACS_Marital_Status_Boundaries/FeatureServer/2",
        popupTemplate: template
      map.add(featureLayer);
      const elevationProfile = new ElevationProfile({
        view: view,
        profiles: [
            type: "ground" // first profile line samples the ground elevation
            type: "view" // second profile samples the view and shows building profiles
        // hide the select button
        // this button can be displayed when there are polylines in the
        // scene to select and display the elevation profile for
        visibleElements: {
          //selectButton: false
      // add the widget to the view
      view.ui.add(elevationProfile, "top-right");
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
KenBuja
Are you seeing any error messages in your console? Can you either post your code or put together a code sample that reproduces the error?
Hi Ken,
I update working file here, you can simply check, I see errors only from imported libraries (it no problem, u can ignore and type error, this u can ignore too, it is old errors 😄 ). I really do not understand what is problem, i out widget at top and at the end too of the code, but get same result 😞
KenBuja
Wow....4300 lines of code is way too much for me to wade through. Can you distill this down to a short example that replicates your problem?
Hi Ken,
Sorry for this :D, i did not notice...
Here is code only with basic widgets and Elevation Profile Widget, also one FL with popupTemplate and Custom Symbol...
I noticed that, before making Elevation profile, popup works, but after i make Profile by clicking on map and it creates graphic line on map (like elevation path), after this i can not call popup 😕
Here is a working file,
Thanks
KenBuja
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      // Create the map
        map: map,
        zoom: 10
      const template = {
        content: [
            type: "fields",
            fieldInfos: [
                label: "Married %"
                format: {
                  places: 0
                format: {
                  places: 0
                format: {
                  places: 0
        view: view,
        profiles: [
        visibleElements: {
  </script>
</head>
<body>
</body>
</html>
Yes, i think same :(,
So what we do know? Let ESRI knw that it is a bug?
KenBuja
Yes, open a case with Esri to verify that it is a bug.
Okay Ken, thank you!
