Popup and Layerlist
2216
12
07-31-2019 06:29 AM
FengYu
New Contributor III
I want to combine the popup function (identify the pixel values or feature attributes for MapService) and layerlist widget, potentially add some other widgets. I follow the example for the ESRI's javascript API description but the widgets seem to be misplaced and the popup does not show in the current location. The content plane has been set to the right and the widgets to the left, but still not working. I would appreciate any inputs regarding this issue.
<!DOCTYPE html>
<html>
 <head>
 <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
 <!--The viewport meta tag is used to improve the presentation and behavior of the samples
 on iOS devices-->
 <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
 <title>soil map</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/themes/calcite/esri/esri.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.29/dijit/themes/claro/claro.css">
 <style>
 html, body, .container, #map {
 height:100%;
 width:100%;
 margin:0;
 padding:0;
 margin:0;
 font-family: "Open Sans";
 #map {
 padding:0;
 #layerListPane{
 width:25%;
 .esriLayer{
 background-color: #fff;
 .esriLayerList .esriList{
 border-top:none;
 .esriLayerList .esriTitle {
 border-bottom:none;
 .esriLayerList .esriList ul{
 #search {
 display: block;
 position: absolute;
 z-index: 3;
 top: 20px;
 left: 75px;
 #HomeButton {
 position: absolute;
 top: 100px;
 left: 15px;
 z-index: 50;
 </style>
 <script>var dojoConfig = { parseOnLoad: true };</script>
 <script src="http://js.arcgis.com/3.29/"></script>
 <script>
 require([
 "esri/dijit/Popup",
 "esri/symbols/SimpleFillSymbol",
 "esri/symbols/SimpleLineSymbol",
 "esri/Color",
 "dojo/dom-construct",
 "esri/map",
 "esri/dijit/HomeButton",
 "esri/layers/ArcGISDynamicMapServiceLayer",
 "esri/dijit/LayerList",
 "esri/dijit/Search",
 "esri/dijit/Legend",
 "esri/dijit/Scalebar",
 "esri/tasks/IdentifyTask",
 "esri/tasks/IdentifyParameters",
 "dojo/_base/array",
 "esri/InfoTemplate",
 "dojo/dom",
 "dijit/layout/BorderContainer",
 "dijit/layout/ContentPane",
 "dojo/domReady!"
 ], function (
 Popup, SimpleFillSymbol, SimpleLineSymbol, Color, domConstruct,
 Map, HomeButton, ArcGISDynamicMapServiceLayer, LayerList, Search, Legend, Scalebar,
 IdentifyTask, IdentifyParameters, arrayUtils, InfoTemplate,
 dom
 var map, identifyTask, identifyParams;
var popup = new Popup({
 fillSymbol: new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
 new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
 new Color([255, 0, 0]), 2), new Color([255, 255, 0, 0.25]))
 }, domConstruct.create("div"));
 map = new Map("map", {
 basemap: "topo",
 center: [-90.125, 40],
 zoom: 8,
 infoWindow: popup
map.on("load", mapReady);
var rasterURL1 = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer";
var operationalLayer1 = new ArcGISDynamicMapServiceLayer(rasterURL1, { opacity: .80 });
 map.addLayers([operationalLayer1]);
var layerList = new LayerList({
 map: map,
 layers: [{
 layer: operationalLayer1,
 showLegend: true,
 showSubLayers: false,
 showOpacitySlider: true
 },"layerList");
 layerList.startup();
var rasterURL2 = "https://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Petroleum/KGS_OilGasFields_Kansas/MapServer";
 map.addLayer(new ArcGISDynamicMapServiceLayer(rasterURL2,
 { opacity: .90 }));
 var search = new Search({
 map: map,
 }, dom.byId("search"));
search.startup();
var home = new HomeButton({
 map: map
 }, "HomeButton");
 home.startup();
var scalebar = new Scalebar({
 map: map,
 scalebarUnit: "dual"
 scalebar.startup();
 function mapReady () {
 map.on("click", executeIdentifyTask);
 //create identify tasks and setup parameters
 identifyTask = new IdentifyTask(rasterURL1);
identifyParams = new IdentifyParameters();
 identifyParams.tolerance = 1;
 identifyParams.returnGeometry = true;
 identifyParams.layerIds = [0,1];
 identifyParams.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
 identifyParams.width = map.width;
 identifyParams.height = map.height;
function executeIdentifyTask (event) {
 identifyParams.geometry = event.mapPoint;
 identifyParams.mapExtent = map.extent;
var deferred = identifyTask
 .execute(identifyParams);
 deferred.addCallback(function (response) {
return arrayUtils.map(response, function (result) {
 var feature = result.feature;
 var layerName = result.layerName;
 //alert(result);
 feature.attributes.layerName = layerName;
 if (layerName === 'Census Block Points') {
 var taxParcelTemplate = new InfoTemplate(layerName,
 "the oject value is: " + feature.attributes['STATE_FIPS']);
 feature.setInfoTemplate(taxParcelTemplate);
 else if (layerName === 'KS_FIELD_OUTLINES_SPRING2005_GEONAD27') {
 "the oject value is: : " + feature.attributes['FIELD_NAME']);
 return feature;
map.infoWindow.setFeatures([deferred]);
 map.infoWindow.show(event.mapPoint);
 </script>
 </head>
<body class="claro">
<div class="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false">
 <div id="layerListPane" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'right'">
 <div id="layerList"></div>
 </div>
<div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'"></div>
<div id="search" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="legendDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
<div id="HomeButton" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div>
</div>
</body>
</html>
RobertScheitlin__GISP
Feng,
Here is your code corrected.
<!DOCTYPE html>
<html>
<head>
 on iOS devices-->
  <link rel="stylesheet" href="https://js.arcgis.com/3.29/esri/css/esri.css">
  <style>
    html,
    body,
    .container,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #map {
      padding: 0;
    #layerListPane {
      width: 25%;
    .esriLayer {
    .esriLayerList .esriList {
      border-top: none;
      border-bottom: none;
    .esriLayerList .esriList ul {
    #search {
      display: block;
      position: absolute;
      z-index: 3;
      top: 20px;
      left: 75px;
    #HomeButton {
      position: absolute;
      top: 100px;
      left: 15px;
      z-index: 50;
  </style>
  <script>
    require([
      "dojo/parser",
      "esri/dijit/Popup",
      "esri/Color",
      "esri/map",
      "dojo/_base/array",
      "dojo/dom",
      "dojo/domReady!"
    ], function (
      parser, Popup, SimpleFillSymbol, SimpleLineSymbol, Color, domConstruct,
      dom
      parser.parse();
        basemap: "topo",
        zoom: 8,
        infoWindow: popup
        opacity: .80
        map: map,
        layers: [{
        showLegend: true,
      }, "layerList");
      var rasterURL2 =
      map.addLayer(new ArcGISDynamicMapServiceLayer(rasterURL2, {
        opacity: .90
        map: map,
      search.startup();
        map: map
      }, "HomeButton");
      home.startup();
        map: map,
      function mapReady() {
        identifyParams.layerIds = [0, 1];
      function executeIdentifyTask(event) {
            //alert(result);
            } else if (layerName === 'KS_FIELD_OUTLINES_SPRING2005_GEONAD27') {
            return feature;
  </script>
</head>
  <div class="container" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%; height:100%;">
    <div id="layerListPane" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'right'">
    </div>
      <div id="search"></div>
      <div id="HomeButton"></div>
    </div>
    <!-- <div id="legendDiv" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'"></div> -->
  </div>
</body>
</html>
Feng,
   You are missing a css file:
Once you add this css file link things will draw better, but you still have a lot of work to do with placement.
FengYu
New Contributor III
Robert,
Thank you for your response. I added this missing css file and it does look better. However, all of the widgets and the layerlist are stacked together on the left. Could you collaborate a bit more about the placement since I have already set the panel to the right?
Feng,
<!DOCTYPE html>
<html>
<head>
 on iOS devices-->
  <style>
    html,
    body,
    .container,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #map {
      padding: 0;
    #layerListPane {
      width: 25%;
    .esriLayer {
      border-top: none;
    #search {
      display: block;
      position: absolute;
      z-index: 3;
      top: 20px;
      left: 75px;
    #HomeButton {
      position: absolute;
      top: 100px;
      left: 15px;
      z-index: 50;
  </style>
  <script>
    require([
      "dojo/parser",
      "esri/dijit/Popup",
      "esri/Color",
      "esri/map",
      "dojo/_base/array",
      "dojo/dom",
      "dojo/domReady!"
    ], function (
      dom
      parser.parse();
        basemap: "topo",
        zoom: 8,
        infoWindow: popup
        opacity: .80
        map: map,
        layers: [{
        showLegend: true,
      }, "layerList");
      var rasterURL2 =
        opacity: .90
        map: map,
      search.startup();
        map: map
      }, "HomeButton");
      home.startup();
        map: map,
            //alert(result);
            return feature;
  </script>
</head>
    </div>
    </div>
  </div>
</body>
</html>
FengYu
New Contributor III
Thank you very much Robert.
I would like to know if you have any comment on the identifyTask? I want to show the values for each layer that is toggled on in the layerlist panel.
Feng,
   My recommendation is not to use IdentifyTask and instead just use standard infoTemplates:
<!DOCTYPE html>
<html>
<head>
 on iOS devices-->
  <style>
    html,
    body,
    .container,
    #map {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
      margin: 0;
    #map {
      padding: 0;
    #layerListPane {
      width: 25%;
    .esriLayer {
      border-top: none;
    #search {
      display: block;
      position: absolute;
      z-index: 3;
      top: 20px;
      left: 75px;
    #HomeButton {
      position: absolute;
      top: 100px;
      left: 15px;
      z-index: 50;
  </style>
  <script>
    require([
      "dojo/parser",
      "esri/dijit/Popup",
      "esri/Color",
      "esri/map",
      "dojo/_base/array",
      "dojo/dom",
      "dojo/domReady!"
    ], function (
      dom
      parser.parse();
        basemap: "topo",
        zoom: 8,
        infoWindow: popup
        opacity: .80,
        infoTemplates: {
          0: {
            infoTemplate: new InfoTemplate('Census Block Points', "the object value is: ${STATE_FIPS}")
          1: {
            infoTemplate: new InfoTemplate('Census Block Group', "the object value is: ${STATE_FIPS}")
        map: map,
        layers: [{
        showLegend: true,
      }, "layerList");
      var rasterURL2 =
        opacity: .90,
        infoTemplates: {
          0: {
            infoTemplate: new InfoTemplate('KS Field', "the object value is: ${FIELD_NAME}")
        map: map,
      search.startup();
        map: map
      }, "HomeButton");
      home.startup();
        map: map,
  </script>
</head>
    </div>
    </div>
  </div>
</body>
</html>
FengYu
New Contributor III
Thanks Robert. So how to use this for raster layers (pixel values)? Some of my raster layers have attribute table but some do not (float type).
Feng,
   OK, rasters will require the use of IdentifyTask. The identifyTask is based on a particular url though. so if each of your layers have a different url then you will have to run a IdentifyTask on each url and get the results before you show the popup. Dojo has a class called "dojo/promise/all" that is just for this use case (i.e. multiple async tasks and waiting for them all to return before proceeding to some code block).
FengYu
New Contributor III
Robert,
Thanks. Would it be possible to provide an example for this? How do I return the currently toggled layers and show specific popups for them?
