polygon-3d extrude showing filled outline edges
1128
8
09-28-2020 10:42 AM
BradCooper2
New Contributor II
I'm trying to show a polygon result of a watershed using a webscene (AGS JS API 4.x and (polygon-3d and extrude feature). What I can't figure out, is there is a way to symbolize the feature to show filled edges and a transparent fill for the main polygon? Basically, i just want the outline of the polygon to be extruded and filled.
BradCooper2
New Contributor II
Thanks, yes, i've gone through the samples a few times now looking for how to do this and i don't see any explain how to do this.
RickeyFight
MVP Regular Contributor
Brad Cooper
Can you post your code or link to the site you are working on?
BradCooper2
New Contributor II
Sure, i put together this sample (borrowed from Esri's sample) to show a box that is filled - https://codepen.io/bcooper/pen/yLOrRjg?editors=1000.
I tried adding an outline style in there (red) for good measure).
RickeyFight
Brad Cooper
<html>
  <head>
    <meta charset="utf-8" />
    <meta
      name="viewport"
      content="initial-scale=1,maximum-scale=1,user-scalable=no"
<title>
     Floating polygon to see about only doing outline and not fill
    </title>
    <link
      rel="stylesheet"
      href="https://js.arcgis.com/4.16/esri/themes/light/main.css"
    <script src="https://js.arcgis.com/4.16/"></script>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
    </style>
    <script>
      require([
        "esri/Map",
        "esri/views/SceneView",
        "esri/layers/GraphicsLayer",
        "esri/Graphic"
      ], function (Map, SceneView, GraphicsLayer, Graphic) {
        var map = new Map({
          basemap: "hybrid"
        var view = new SceneView({
          container: "viewDiv",
          map: map,
          camera: {
            // autocasts as new Camera()
            position: {
              // autocasts as new Point()
              x: -0.17746710975334712,
              y: 51.44543992422466,
              z: 1266.7049653716385
            heading: 0.34445102566290225,
            tilt: 82.95536300536367
         * Add graphics layer
        var graphicsLayer = new GraphicsLayer();
        map.add(graphicsLayer);
         * Add a 3D polygon graphic
        var polygon = {
          type: "polygon", // autocasts as new Polygon()
          rings: [
            [-0.184, 51.48391],
            [-0.184, 51.49091],
            [-0.172, 51.49091],
            [-0.172, 51.48391],
            [-0.184, 51.48391]
       var threeDfillSymbol2 = {
          type: "polygon-3d", // autocasts as new PolygonSymbol3D()
  symbolLayers: [
      type: "extrude",
      // autocasts as new ExtrudeSymbol3DLayer()
      material: {
        color: [67, 145, 244, 0.5] // orange
      edges: {
        // add edges of type solid
        type: "solid",
        color: "#AF6515" // dark orange
        var polygonGraphic = new Graphic({
          geometry: polygon,
          symbol: threeDfillSymbol2
        graphicsLayer.add(polygonGraphic);
    </script>
  </head>
  <body>
    <div id="viewDiv"></div>
  </body>
</html>
BradCooper2
New Contributor II
Thanks but I'm looking to have the middle (volume) unfilled. I only want the outside outline of the polygon that was extruded to be filled (i.e. in-between the edges). Think of it as a shoe box with no top or bottom, just the sides.
BradCooper2
New Contributor II
Rickey Fite‌ Any other thoughts? Thanks!
RickeyFight
Brad Cooper
The only way I can think of is to make the polygon into a line. I don't think that is what you are looking for though.
