passing values to infowindow of corresponding marker
2875
6
02-22-2016 10:42 PM
SyedaSamina
Hi, im totally new to ArcGIS. I've been spending some time with the JavaScript API, i'm stuck on this one. i have a json string. and reading values from that string i add markers to my map using loop. i want to pass values to each marker. i have added a click event to display my passed values to info window. but thats showing the values saved in last itertion onclick of each marker. i know there s solution to this problem but im unable to find one.
I want to find out the way that each marker pop up displays its own city name using this json string.
<!DOCTYPE html>
<html>
<head>
  <title>Create a Map</title>
  <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="https://js.arcgis.com/3.15/esri/css/esri.css">
  <style>
    html, body, #mapDiv{
      padding: 0;
      margin: 0;
      height: 100%;
  </style>
  <script src="https://js.arcgis.com/3.15/"></script>
  <script>
    var map;
    require(["esri/map",
    "esri/graphic",
    "esri/symbols/PictureMarkerSymbol",
    "esri/symbols/TextSymbol",
    "esri/geometry/Point",
    "esri/SpatialReference",
    "esri/tasks/ProjectParameters",
    "esri/tasks/GeometryService",
    "dojo/on",
    "dojo/domReady!"
        ], function setupmap(Map, Graphic, PictureMarkerSymbol, TextSymbol, Point, SpatialReference, ProjectParameters, GeometryService, on) {
      map = new Map("mapDiv", {
        center: [70.45, 30.75],
        zoom: 6,
        basemap: "streets"
  var jsonString = { locations: [{ latitude: 28.75, longitude: 69.45, CityName: 'Lahore' ,total:1100}, { latitude: 33.75, longitude: 69.45, CityName: 'PSC' ,total:2100},{ latitude: 30.75, longitude: 70.45, CityName: 'rwp' ,total:90}] };
            jsonString = jsonString.locations;
            picSymbol = new PictureMarkerSymbol('http://static.arcgis.com/images/Symbols/Shapes/BluePin1LargeB.png', 80, 80);
            map.on("load", function (evt) {
                for (var i = 0; i < jsonString.length; i++) {
                    var geometryPoint = new Point(jsonString.longitude, jsonString.latitude, new SpatialReference(4326));
                    textSymbol = new TextSymbol(jsonString.CityName).setOffset(0, -4);
                    var CityName =jsonString.CityName;
                    map.graphics.add(new Graphic(geometryPoint, picSymbol));
                       map.graphics.add(new Graphic(geometryPoint, textSymbol));
                    map.graphics.on("click",function show(evt){map.infoWindow.setTitle("Coordinates");
                      map.infoWindow.setContent("City Name is :"+ CityName);
                      map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));});
  </script>
</head>
<body class="claro">
  <div id="mapDiv"></div>
</body>
</html>
TyroneBiggums
Occasional Contributor III
The click event occurs after your loop is complete. By the time you click the graphic, the city name that you set for the infoWindow will always be the city name of the last iteration of the loop, 'rwp'.
TyroneBiggums
SyedaSamina
Yes it is, then how can i get the right name displayed ? Tyrone Biggums
TyroneBiggums
There are a few ways around it. Here is one http://stackoverflow.com/questions/7530678/javascript-variable-scope-issue-with-jquery-click-event
But, what you'll want to googles is javascript event scope issues to get more information on it.
AjySha
Hi , have you find out solution of problem ?
Can you share it please ?
AjySha
Greetings!!!
Have you find out solution of this issue ?
Please let me know
Best Regards.
AjySha
I have found solution of it. Thanks
If anybody want contact me.
Regards.
