Passing URL Parameters to Query Feature Layers
2848
07-12-2020 02:52 AM
RonParis
Is it possible to query a feature service using parameters that are within the URL?
My scenario is that is a user scans a QR code on a mobile device, this then launches a webpage with JS map in it, and it then zooms in on the feature relating to the QR code they have scanned. This scenario is similar to what can be achieved in WebApp Builder.
TIA
Tags (3)
Egge-Jan_Pollé
MVP Regular Contributor
Hi Josh Harris,
Yes, this is possible 🙂
Please see the example below using the URLSearchParams interface.
It will read the municipality name from the url and zoom in to the relevant municipality.
HTH,
Egge-Jan
Just 3 examples:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
  <title>Aan de slag met ArcGIS JavaScript - Query FeatureLayer met URL Parameters</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.16/esri/css/main.css">
  <script src="https://js.arcgis.com/4.16/"></script>
  <style>
    html, body, #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
      require([
        "esri/Map",
        "esri/geometry/Point",
        "esri/views/MapView",
        "esri/layers/FeatureLayer",
        "esri/widgets/LayerList"
      ], function(Map, Point, MapView, FeatureLayer, LayerList) {
      var map = new Map({
        basemap: {
          portalItem: {
            id: "7aea6fa913a94176a1074edb40690318" // Topo RD
      var popupTemplate = { // autocasts as new PopupTemplate()
        title: "Gemeente {Gemeentenaam}",
        content: "Gemeentecode {GM_Code}"
      var renderer = {
        type: "simple",  // autocasts as new SimpleRenderer()
        symbol: {
          type: "simple-fill",  // autocasts as new SimpleFillSymbol()
          style: "none", // The polygon has no fill
          outline: {  // autocasts as new SimpleLineSymbol()
            width: 1.5,
            color: "#F5B041" // Hex Color Code
      if ('URLSearchParams' in window) { // Feature detection (URLSearchParams is not supported by Internet Explorer)
        var url = new URL(document.URL);
        var search_params = url.searchParams;
        if(search_params.has('m')) {
          var municipality = search_params.get('m');
          var expr = "Gemeentenaam  = '" + municipality + "'";
        } else {
          var municipality = "";
          var expr = "1=1";
      var municipalityLayer = new FeatureLayer({
        url: "https://services.arcgis.com/nSZVuSZjHpEZZbRo/arcgis/rest/services/Bestuurlijke_Grenzen_Gemeenten_2019/FeatureServer/0",
        definitionExpression: expr,
        title: "Gemeenten " + municipality,
        minScale: 5000000,
        popupTemplate: popupTemplate,
        renderer: renderer
      map.add(municipalityLayer);
	  var view = new MapView({
	    spatialReference: 28992,
	    container: "viewDiv",
	    map: map,
	    center: new Point({x: 155000, y: 463000, spatialReference: 28992}),
	    zoom: 3
      var layerList = new LayerList({
        view: view
      view.ui.add(layerList, {
        position: "top-right"
      municipalityLayer
        .when(function() {
          return municipalityLayer.queryExtent();
        .then(function(response) {
          view.goTo(response.extent);
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
RonParis
Hi Egge-Jan,
That is perfect, exactly what I'm after! Unfortunately, I'm a bit stuck; I can get the map to filter the feature and only show it on the map, but I can't get it to do the zoom bit. Any ideas as to why this would be?
Egge-Jan_Pollé
Hi Josh Harris,
For the zoom bit, please have a look at this example: Zoom to extent of all features | ArcGIS API for JavaScript 4.16
As you can see in my example, 1) a single municipality is filtered out, 2) this municipality is added to the map, 3) the extent of this layer is queried and then you can zoom in with view.goTo().
// When the layer is loaded, query for the extent
// of all features in the layer. Then set the view's
// extent to the returned extent of all features.
layer
  .when(function() {
    return layer.queryExtent();
HTH,
Egge-Jan
RonParis
Hi Egge-Jan, the issue seems to be when I change the spatial reference from 28992 to 3395. Please see below (fyi, I've starred out the feature service url).
<!DOCTYPE html>
<html>
<head>
 <style>
 padding: 0;
 margin: 0;
 height: 100%;
 width: 100%;
 </style>
 <script>
 require([
 "esri/Map",
var map = new Map({
 basemap: "topo-vector"
 title: "ID {map16_tree_id}",
 content: "ID {map16_tree_id}"
var renderer = {
 symbol: {
 width: 1.5,
 var expr = "map16_tree_id = '" + municipality + "'";
 } else {
 var expr = "1=1";
 url: "************",
 title: municipality,
 minScale: 5000000,
 renderer: renderer
 spatialReference: 3395,
 map: map,
 center: new Point({x: -2.621237, y: 51.477442, spatialReference: 3395}),
 zoom: 19
 view: view
 municipalityLayer.when(function() {
 </script>
</head>
<body>
</body>
Egge-Jan_Pollé
Hi Josh Harris,
OK - I just provided an example to show how you can pass url parameters to query feature layers. (And yes, I did use some Dutch data in this example, so that's why the view has 28992 as a spatial reference.)
It is up to you now to apply this workflow to your own data. I am unable to test your code, because you starred out quite an essential part, i.e. the input feature service url. So I can't tell what is going well and what is going wrong.
What browser are you using? Do you see any error messages in the console?
Please let us know how you managed to solve the issue.
Egge-Jan
