Pass value of address variable into the search widget on a mapview ... have search auto execute?
736
09-12-2018 08:43 AM
JohnRichardson
Brand new to Javascript and the ArcGIS API .... so please forgive me if this is a simple question ... but how can I pass a value of an address variable into the search widget of a mapview and have the search execute automatically?
JohnGrayson
As Robert points out via the provided link, you should call the 'search' method:
 searchWidget = new Search({
    view:view,
    searchTerm: "1024 E 8th"
 view.ui.add(searchWidget, "bottom-right");
view.when(()=>{
   searchWidget.search();
RobertScheitlin__GISP
JohnRichardson
searchWidget = new Search({ //add the search widget to the map view
view:view
addy = searchWidget.searchTerm = "1024 E 8th";
searchWidget(addy);
the above code will not execute the search for me ... it populates the search field in the widget, just does not run the search and zoom to result
JohnGrayson
    view:view,
view.when(()=>{
JohnRichardson
Yes!
Thank you all very much ...
view.when(()=>{
The above bit of code did the trick!!
