My application displays multiple types of features with differing symbols using a feature layer with a unique value renderer, like so
type: 'unique-value',
valueExpression: `When($feature.type == 'someType', '1',
$feature.type == 'someType', '2',
$feature.type == 'someType', '3',
'0')`,
uniqueValueInfos: [{
value: '1',
symbol: someSymbol,
value: '2',
symbol: someSymbol,
value: '3',
symbol: someSymbol,
This works very well, however upon adding a featureReductionCluster to the feature layer, the generated cluster symbols seem to be a random selection of of the features it represents, albeit a different size.
Removing the valueExpression and specifying defaultSymbol in the renderer gets around this, as the cluster symbol inherits the symbol/size from the default.
However due to the nature of my use case I am required to perform some advanced differentiation, requiring the use of valueExpression with an Arcade expression.
Is there a way to retain the use of valueExpression on a renderer and still have control over the cluster symbol?
Apparently there's an undocumented symbol property in FeatureReductionCluster - https://community.esri.com/t5/arcgis-api-for-javascript-ideas/arcgis-javascript-4-cluster-renderer/i...
