OutStatistics with Time Slider
1630
7
08-19-2021 02:55 PM
cschooley
New Contributor III
Hey there. Learning the Javascript API still and I'm trying to calculate some out statistics that then displays that info in an information box. These statistics are the GDP, Employment numbers, etc of each year for the Oil and Gas industry in Utah.
I keep getting an error related to the outStatistics when I try.
Here's the error in my console:
Here's the link to the feature layer:
Oil and Gas Well Locations Feature Layer
Here's the link to the website:
Oil and Gas Time Lapse Application
Here's Javascript Code:
require([
  "esri/Map",
  "esri/views/MapView",
  "esri/layers/FeatureLayer",
  "esri/widgets/Expand",
  "esri/widgets/Legend",
  "esri/widgets/TimeSlider"
], function (Map, MapView, FeatureLayer, Expand, Legend, TimeSlider) {
let OGLayerView;
  const layer = new FeatureLayer({
    portalItem: {
  // Create Map
const map = new Map({
  basemap: "topo",
  layers: [layer]
 // Set the map view
const view = new MapView({
  container: "viewDiv",
  map: map,
  center: [-111.65124179920204, 39.707361735142236],
  zoom:7
// Create a collapsible legend
const legendExpand = new Expand({
  collapsedIconClass: "esri-icon-collapse",
  expandIconClass: "esri-icon-expand",
  expandTooltip: "Legend",
  view: view,
  content: new Legend({
    view: view
  expanded: false
view.ui.add(legendExpand, "top-left");
// Create events for the time slider
const events = [
  {name:`Great Recession`, date: 2008},
  {name: `Covid-19 Pandemic`, date: 2020}
// Create time slider with interval set to 5 years
const timeSlider = new TimeSlider({
    container: "timeSlider",
    playRate: 750,
    stops: {
      interval: {
        value: 5,
        unit: "years"
    // time slider time extent
    //fullTimeExtent: {
       // start: new Date(1900,0,1),
       // end: new Date(2022,0,1)
    // configure ticks for dates
    tickConfigs: [{
      mode: "position",
      values: [
        new Date(1900, 0, 1), new Date(1910, 0, 1), new Date(1920, 0, 1), new Date(1930, 0, 1), new Date(1940, 0, 1), new Date(1950, 0, 1), new Date(1960, 0, 1), new Date(1970, 0, 1),
        new Date(1980, 0 , 1), new Date(1990, 0, 1), new Date(2000, 0, 1), new Date(2010, 0, 1), new Date(2020, 0, 1)
      ].map((date) => date.getTime()),
      labelsVisible: true,
      labelFormatFunction: (value) => {
        const date = new Date(value);
        return `${date.getUTCFullYear()}`;
      tickCreatedFunction: (value, tickElement, labelElement) => {
        tickElement.classList.add("custom-ticks2");
        labelElement.classList.add("custom-labels2");
      mode: "position",
      values: events
        .map((event) => new Date(event.date, 0, 1))
        const event = events.find(
          (s) => new Date(s.date, 0, 1).getTime() === value
        return event.name;
        tickElement.classList.add("custom-ticks");
        labelElement.classList.add("custom-labels");
// add time slider to view
view.ui.add(timeSlider);
// Creating view layer???
view.whenLayerView(layer).then((layerView) => {
  OGLayerView = layerView;
// Setting start date for time slider
  const start = new Date(1900, 0, 1);
 // Extent for time Slider
  timeSlider.fullTimeExtent = {
    start: start,
    end: layer.timeInfo.fullTimeExtent.end
// Show 5 year intervals
let end = new Date(start);
end.setDate(end.getDate() + 1825); // the number here is in days (1825 = 5 years)
timeSlider.timeExtent = {start,end};
// watch timeslider timeExtent change
timeSlider.watch("timeExtent", () => {
  //oil wells that popped up before the end of the current time extent
OGLayerView.filter = {
  where: "OrigComplDate <=" + timeSlider.timeExtent.end.getTime(),
// add grayscale effect to old wells (may or may not keep this)
  OGLayerView.effect = {
    filter: {
      timeExtent:timeSlider.timeExtent,
      geometry: view.extent
    excludedEffect: "grayscale(80%) opacity(20%)"
// Run statistics for GDP within current time extent
const statQuery = OGLayerView.effect.filter.createQuery();
statQuery.outStatistics = [
GDPAvg
layer.queryFeatures(statQuery).then((result) => {
let htmls = [];
statsDiv.innerHTML = "";
if (result.error) {
  return result.error;
} else {
  if (result.feature.length >= 1) {
    const attributes = result.features[0].attributes;
    for (stat in statsFields) {
      if (attributes[name] && attributes[name] != null) {
        const html =
        "<br/>" +
        statsFields[name] +
        ": <b><span>" + // setting bolding and styling
        attributes[name].toFixed(0) + // How many decimal places
        "</span></b>"; // setting bolding and styling to attribute information
        htmls.push(html) // push html into code into information box with attribute information
    const yearHtml =
      "<span>" +
      result.features[0].attributes["GDP_Average"] +
      "</span> billion dollars was added to Utah's GDP by the Oil and Gas Industry between" +
      timeSlider.timeExtent.start.toLocaleDateString() +
      " and " +
      timeSlider.timeExtent.end.toLocaleDateString() +
      ".<br/>";
    if (htmls[0] == undefined) {
      statsDiv.innerHTML = yearHtml;
    } else {
        yearHtml + htmls[0];
.catch((error) => {
console.log(error);
const GDPAvg = {
  onstatisticField: "GDP_billions_", //using field name instead of field alias??? Don't know if I should. I have tried both ways now
  outStatisticFieldName: "GDP_Average",
  statisticType: "avg"
const statsFields = {
  GDP_Average: "GDP Average"
const statsDiv = document.getElementById("statsDiv");
      const infoDiv = document.getElementById("infoDiv");
      const infoDivExpand = new Expand({
        expandTooltip: "Expand Oil and Gas Industry info",
        view: view,
        content: infoDiv,
        expanded: true
      view.ui.add(infoDivExpand, "top-right");
If you want:
HTML Code:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>OGM Time Lapse</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.20/esri/themes/light/main.css">
  <link rel="stylesheet" href="main.css">
  <script src="https://js.arcgis.com/4.20/"></script>
  <script type = "text/javascript" src="main.js"></script>
</head>
<body>
  <div id="viewDiv"></div>
  <div id="timeSlider" class = "sample-slider"></div>
  <div id="infoDiv" class="esri-widget">
    <div> <b>Growth of the Oil and Gas Industry</b></div><br/>
    <div id="statsDiv" class="esri-widget"></div>
  </div>
</body>
</html>
CSS Code:
html,
body,
#viewDiv {
	padding: 0;
	margin: 0;
	height: 100%;
	width: 100%;
.sample-slider {
	position: absolute;
	left: 2%;
	right: 2%;
	bottom: 20px;
	margin: 20px ;
#timeSlider .custom-labels{
	font-family: Georgia, 'Times New Roman', Times, serif;
	font-size: 10px;
	color: red;
	margin-top: -35px;
#timeSlider .custom-ticks{
	background-color: black;
	width: 1px;
	height: 8px;
	margin-top: -30px;
#timeSlider .custom-labels2{
	font-size: 12px;
	font-weight: bold;
	color: black;
	margin-top: 7 px;
#timeSlider .custom-ticks2{
	width: 1px;
	height: 8px;
	margin-top: 2px;
.esri-time-slider__slider .esri-slider {
    margin-top: -5px;
#infoDiv {
	height: 200px;
	padding: 10px;
	width: 280px;
#infoDiv span {
	color: #77496B;
	font-size: 12pt;
	font-weight: bolder;
#titleDiv {
	padding: 10px
#titleText {
	font-size: 20pt;
	font-weight: 60;
	padding-bottom: 10px;
Link to sample code from Esri that I've been referencing:
Esri Filter with Time Slider Example
Whole code if you want:
<html>
  <head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no"/>
    <title>Filter features with TimeSlider | Sample | ArcGIS API for JavaScript 4.20</title>
    <style>
      html,
      body,
      #viewDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #timeSlider {
        width: 400px;
      #infoDiv {
        height: 200px;
        padding: 10px;
        width: 280px;
      #infoDiv span {
        color: #F9C653;
        font-size: 12pt;
    </style>
    <link rel="stylesheet" href="https://js.arcgis.com/4.20/esri/themes/dark/main.css" />
    <script>
      require([
        "esri/Map",
        "esri/layers/GeoJSONLayer",
        "esri/widgets/TimeSlider",
      ], (Map, MapView, GeoJSONLayer, TimeSlider, Expand, Legend) => {
        let layerView;
        // set the timeInfo on GeoJSONLayer at the time initialization
        const layer = new GeoJSONLayer({
          url: "https://bsvensson.github.io/various-tests/geojson/usgs-earthquakes-06182019.geojson",
          copyright: "USGS Earthquakes",
          title: "USGS Earthquakes",
          // set the CSVLayer's timeInfo based on the date field
          timeInfo: {
            startField: "time", // name of the date field
            interval: {
              // set time interval to one day
              unit: "days",
              value: 1
          renderer: {
            type: "simple",
            field: "mag",
            symbol: {
              type: "simple-marker",
              color: "orange",
              outline: null
            visualVariables: [
                type: "size",
                field: "mag",
                stops: [
                    value: 1,
                    value: 2,
                    value: 3,
                type: "color",
                field: "depth",
                stops: [
                    value: 2.5,
                    color: "#F9C653",
                    label: "<2km"
                    value: 3.5,
                    color: "#F8864D",
                    label: "3km"
                    value: 4,
                    color: "#C53C06",
                    label: ">4km"
          popupTemplate: {
            title: "{title}",
            content: [
                type: "fields",
                fieldInfos: [
                    fieldName: "place",
                    label: "Location",
                    visible: true
                    fieldName: "mag",
                    label: "Magnitude",
                    visible: true
                    fieldName: "depth",
                    label: "Depth",
                    visible: true
          basemap: "dark-gray-vector",
          layers: [layer]
          map: map,
          zoom: 13,
          center: [-117.512764, 34.04355]
        // create a new time slider widget
        // set other properties when the layer view is loaded
        // by default timeSlider.mode is "time-window" - shows
        // data falls within time range
          playRate: 50,
          stops: {
            interval: {
              value: 1,
              unit: "hours"
        view.ui.add(timeSlider, "bottom-left");
        // wait till the layer view is loaded
        view.whenLayerView(layer).then((lv) => {
          layerView = lv;
          // start time of the time slider - 5/25/2019
          const start = new Date(2019, 4, 25);
          // set time slider's full extent to
          // 5/25/5019 - until end date of layer's fullTimeExtent
            start: start,
          // We will be showing earthquakes with one day interval
          // when the app is loaded we will show earthquakes that
          // happened between 5/25 - 5/26.
          // end of current time extent for time slider
          // showing earthquakes with one day interval
          end.setDate(end.getDate() + 1);
          // timeExtent property is set so that timeslider
          // widget show the first day. We are setting
          // the thumbs positions.
          timeSlider.timeExtent = {start, end};
        // watch for time slider timeExtent change
          // only show earthquakes happened up until the end of
          // timeSlider's current time extent.
          layer.definitionExpression =
            "time <= " + timeSlider.timeExtent.end.getTime();
          // now gray out earthquakes that happened before the time slider's current
          // timeExtent... leaving footprint of earthquakes that already happened
          layerView.effect = {
            filter: {
              timeExtent: timeSlider.timeExtent,
            excludedEffect: "grayscale(20%) opacity(12%)"
          // run statistics on earthquakes fall within the current time extent
          const statQuery = layerView.effect.filter.createQuery();
            magMax,
            magAvg,
            magMin,
            tremorCount,
            avgDepth
              let htmls = [];
              if (result.error) {
              } else {
                if (result.features.length >= 1) {
                  for (name in statsFields) {
                      const html =
                        "<br/>" +
                        statsFields[name] +
                        ": <b><span> " +
                        attributes[name].toFixed(2) +
                        "</span></b>";
                      htmls.push(html);
                  const yearHtml =
                    "<span>" +
                    result.features[0].attributes["tremor_count"] +
                    "</span> earthquakes were recorded between " +
                    ".<br/>";
                  } else {
                      yearHtml + htmls[0] + htmls[1] + htmls[2] + htmls[3];
            .catch((error) => {
              console.log(error);
        const avgDepth = {
          onStatisticField: "depth",
          outStatisticFieldName: "Average_depth",
        const magMax = {
          onStatisticField: "mag",
          outStatisticFieldName: "Max_magnitude",
          statisticType: "max"
        const magAvg = {
          outStatisticFieldName: "Average_magnitude",
        const magMin = {
          outStatisticFieldName: "Min_magnitude",
          statisticType: "min"
        const tremorCount = {
          outStatisticFieldName: "tremor_count",
          statisticType: "count"
          Max_magnitude: "Max magnitude",
          Average_magnitude: "Average magnitude",
          Min_magnitude: "Min magnitude",
          Average_depth: "Average Depth"
        // add a legend for the earthquakes layer
          view: view,
            view: view
          expanded: false
          expandTooltip: "Expand earthquakes info",
          view: view,
          content: infoDiv,
          expanded: true
    </script>
  </head>
  <body>
    <div id="timeSlider"></div>
      <div> <b>USGS Earthquakes</b></div><br/>
    </div>
  </body>
</html>
Any and all suggestions are much appreciated. Javascript isn't a language I am well-versed with. Still in the beginner stages of learning how it all works. Pretty good with python, so I understand the basics of loops, functions, etc.
KenBuja
MVP Esteemed Contributor
The reason you were getting an error is due to a case problem
const GDPAvg = {
Line 2 should  be "onStatisticField"
You closed off the timeSlider watch function too early (at line 144 of your first code fragment instead of 192)
Another problem is on line 158 , which should be "features" instead of "feature"
Here's the code I'm working with, which is still giving me a Null for the line 282 where it reports the result
<html>
<head>
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #timeSlider {
      width: 400px;
    #infoDiv {
      height: 200px;
      padding: 10px;
      width: 280px;
      #infoDiv span {
        color: #F9C653;
        font-size: 12pt;
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .sample-slider {
      position: absolute;
      left: 2%;
      right: 2%;
      bottom: 20px;
      margin: 20px;
    #timeSlider .custom-labels {
      font-size: 10px;
      color: red;
      margin-top: -35px;
    #timeSlider .custom-ticks {
      width: 1px;
      height: 8px;
      margin-top: -30px;
    #timeSlider .custom-labels2 {
      font-size: 12px;
      font-weight: bold;
      color: black;
      margin-top: 7 px;
    #timeSlider .custom-ticks2 {
      width: 1px;
      height: 8px;
      margin-top: 2px;
      margin-top: -5px;
    #infoDiv {
      height: 200px;
      padding: 10px;
      width: 280px;
      #infoDiv span {
        color: #77496B;
        font-size: 12pt;
    #titleDiv {
      padding: 10px
    #titleText {
      font-size: 20pt;
      font-weight: 60;
  </style>
  <script>
    require([
      "esri/Map",
      let OGLayerView;
        portalItem: {
      // Create Map
        basemap: "topo",
        layers: [layer]
      // Set the map view
        map: map,
        zoom: 7
        view: view,
          view: view
        expanded: false
      const events = [
        { name: `Great Recession`, date: 2008 },
        { name: `Covid-19 Pandemic`, date: 2020 }
        playRate: 750,
        stops: {
          interval: {
            value: 5,
            unit: "years"
        //fullTimeExtent: {
        tickConfigs: [{
          mode: "position",
          values: [
            new Date(1980, 0, 1), new Date(1990, 0, 1), new Date(2000, 0, 1), new Date(2010, 0, 1), new Date(2020, 0, 1)
          mode: "position",
          values: events
            return event.name;
          start: start,
        timeSlider.timeExtent = { start, end };
          filter: {
          GDPAvg
          let htmls = [];
          if (result.error) {
          } else {
                  const html =
                    "<br/>" +
                    statsFields[name] +
              const yearHtml =
                "<span>" +
                " and " +
                ".<br/>";
              } else {
          .catch((error) => {
            console.log(error);
        const GDPAvg = {
          onStatisticField: "GDP_billions_", //using field name instead of field alias??? Don't know if I should. I have tried both ways now
        view: view,
        content: infoDiv,
        expanded: true
  </script>
</head>
<body>
  <div id="timeSlider" class="sample-slider"></div>
    <div> <b>Growth of the Oil and Gas Industry</b></div><br />
  </div>
</body>
</html>
KenBuja
const GDPAvg = {
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    #timeSlider {
      width: 400px;
    #infoDiv {
      height: 200px;
      padding: 10px;
      width: 280px;
      #infoDiv span {
        color: #F9C653;
        font-size: 12pt;
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
    .sample-slider {
      position: absolute;
      left: 2%;
      right: 2%;
      bottom: 20px;
      margin: 20px;
      font-size: 10px;
      color: red;
      margin-top: -35px;
      width: 1px;
      height: 8px;
      margin-top: -30px;
      font-size: 12px;
      font-weight: bold;
      color: black;
      margin-top: 7 px;
      width: 1px;
      height: 8px;
      margin-top: 2px;
      margin-top: -5px;
    #infoDiv {
      height: 200px;
      padding: 10px;
      width: 280px;
      #infoDiv span {
        color: #77496B;
        font-size: 12pt;
    #titleDiv {
      padding: 10px
    #titleText {
      font-size: 20pt;
      font-weight: 60;
  </style>
  <script>
    require([
      "esri/Map",
      let OGLayerView;
        portalItem: {
      // Create Map
        basemap: "topo",
        layers: [layer]
      // Set the map view
        map: map,
        zoom: 7
        view: view,
          view: view
        expanded: false
      const events = [
        playRate: 750,
        stops: {
          interval: {
            value: 5,
            unit: "years"
        //fullTimeExtent: {
        tickConfigs: [{
          mode: "position",
          values: [
          mode: "position",
          values: events
            return event.name;
          start: start,
          filter: {
          GDPAvg
          let htmls = [];
          if (result.error) {
          } else {
                  const html =
                    "<br/>" +
                    statsFields[name] +
              const yearHtml =
                "<span>" +
                " and " +
                ".<br/>";
              } else {
          .catch((error) => {
            console.log(error);
        const GDPAvg = {
        view: view,
        content: infoDiv,
        expanded: true
  </script>
</head>
<body>
  </div>
</body>
</html>
cschooley
New Contributor III
Thank you.
I need to take some more time reading through my code for the little case and spelling errors like that. I wrote and rewrote the code, trying to understand how it was working (versus just copy and pasting). I think I got tunnel-visioned.
And thanks for the note on closing the timeSlider. The opening and closing of blocks still confuse me a bit.
This worked for me, after making those changes. You are still getting a null value because, in my data, I don't have GDP data until about 1967. I'm still tracking down earlier data in data archives, non-digital ones. If you hit play on the timeSlider, around the 1960s the statistics start to show up.
KenBuja
There's also a mistake on Line 269.
but you're using "name" in the loop
cschooley
New Contributor III
Thank you. I just caught that one.
KenBuja
And once I let it run to the end, I got the statistics showing up. You should format that statistic so you don't get "943.345425518852 billion dollars"
cschooley
New Contributor III
I just added a .toFixed() into the code to help with that.
Thank you!
const yearHtml =
      "<span>" +
      result.features[0].attributes["GDP_Average"].toFixed(1) +
      " and " +
      ".<br/>";
cschooley
New Contributor III
If you're still around or someone else feels like answering it. I am having an issue with the statistics side of this. I have the effect working correctly, but the statistics are being done on everything before the end of the current time extent, not for each year as I would like. There are notes in the code itself as well.
require([
  "esri/Map",
let OGLayerView;
    portalItem: {
  // Create Map
  basemap: "topo",
  layers: [layer]
 // Set the map view
  map: map,
  center: [-110.16577367032687, 39.014084295303114],    // Centered on Green River for now
  zoom:6.999
  view: view,
    view: view
  expanded: false
const events = [
    playRate: 750,
    stops: {
      interval: {
        value: 1,
        unit: "years"
    //fullTimeExtent: {
    tickConfigs: [{
      mode: "position",
      values: [
        new Date(1970, 0, 1), new Date(1980, 0 , 1), new Date(1990, 0, 1), new Date(2000, 0, 1), new Date(2010, 0, 1), new Date(2020, 0, 1)
      mode: "position",
      values: events
        return event.name;
  const start = new Date(1970, 0, 1);
    start: start,
end.setDate(end.getDate() + 364); // the number here is in days (1825 = 5 years)
  where: "OrigComplDate <=" + timeSlider.timeExtent.end.getTime(), ///PERHAPS THIS IS THE ISSUE WITH IT GOING BEFORE
}        /// I have removed it/adjusted it and continues so maybe not
    filter: {
      timeExtent:timeSlider.timeExtent //Thought this filter would do the time extent as I wanted
const statQuery = OGLayerView.effect.filter.createQuery(); //Is this where I need to filter to extent? I don't think so
GDPAvg,
employmentCount,
wellCounts
if (result.error) {
} else {
    var yearOnly = {year:'numeric'}; //set to show year only in date strings
    const yearHtml =
      "Between " +
      "<span>" +
      timeSlider.timeExtent.start.toLocaleDateString("en-US", yearOnly) +
      "</span> and <span>" +
      timeSlider.timeExtent.end.toLocaleDateString("en-US", yearOnly) +
      "</span> the Oil and Gas Industry in Utah:<br />";
      var thousandsSep = {maximumFractionDigits:0}; //create thousands seperators
    const oilHtml =
    "Had <span>" +
    result.features[0].attributes["Well_Counts"].toLocaleString("en-US", thousandsSep) +
    "</span> oil and gas wells" +
    ".<br/ >";
    const GDPHtml =
    "Added " +
    "<span>" +
    "</span> million dollars to Utah's Gross Domestic Product" +
    ".<br />";
    const employmentHtml =
    "Employed " +
    "<span>" +
    result.features[0].attributes["Employment_Count"].toLocaleString("en-US", thousandsSep) +
    "</span> employees. This includes full and part-time direct and supporting employees" +
    ".<br />";
    const referenceHtml =
    "<i><font size = '1'>" +
    "Estimates from the US Bureau of Economic Analysis and Utah's Division of Oil, Gas, and Mining" +
     "</font></i>";
      yearHtml + "<ul> <li>" + oilHtml + "</li> <li>"  + GDPHtml + "</li> <li>" + employmentHtml + "</li> </ul>" + referenceHtml;
.catch((error) => {
console.log(error);
const GDPAvg = {
const employmentCount = {
  onStatisticField: "Employed",
  outStatisticFieldName: "Employment_Count",
const wellCounts = {
  onStatisticField: "API",
  outStatisticFieldName: "Well_Counts",
        view: view,
        content: infoDiv,
        expanded: true
Any help is appreciated. Thanks!
