Output PDF from Print Task has vector offset
879
07-12-2021 05:55 AM
GreggRoemhildt2
New Contributor III
Hello - I have published a custom print task using Pro. It is nothing special, it just uses a few custom layout files from Pro.
When I generate a PDF using the 4.x javascript api - there is an offset in the vector layers vs. the basemap.
The vector layer is a parcel polygon layer that is projected in UTM 15 N.
The Basemap is a vector tile layer with the same data.
Any ideas what could be causing this?
TanuHoque
@GreggRoemhildt2
can you pls send me data etc. to help me reproduce this in-house? thanks
Tanu
GreggRoemhildt2
New Contributor III
@TanuHoqueI pm'd you with the data. Let me know if you were able to reproduce the issue or have any feedback.
