Needing help querying Map Service for PoPUP
4260
10
09-01-2014 09:09 PM
CharlesGant
New Contributor III
I have the following service loaded into my map:
http://gis.fema.gov/REST/services/FEMA/LSR/MapServer
I would like to be able to sample the graphics from this service in a popup as if it is loaded into an AGOL Webmap.  Unless I'm confused, the above link is to a Map Service and not Feature Layer.  However, when I inspect the layers, they area labeled as Feature Layers.  I read somewhere that you cannot query a Map Service for features.  So I'm confused.  Can I query this layer to be able to display ALL attributes in a popup?  If so, how?
Thanks in advance
EhabEl-Masry
New Contributor II
Hi Charles
u can try this esri sample, with few editing, u should be able to query any layer in your map service..
here u are:
Feature layer hover | ArcGIS API for JavaScript
From your service directory, your layers supports the "Query" REST function.
CharlesGant
New Contributor III
I appreciate the response. I tried incorporating the code and the console prints out:
TooltipDialog in not a constructor
I have all the following in the require and function calls, exactly as it is in the example.  I do have many other requires, however I'm fairly certain that I have the order consistent because the page loads fine.  Typically if the order is out, the page bombs on load.
      require([
"esri/map", "esri/layers/FeatureLayer",
"esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer", "esri/graphic", "esri/lang",
"esri/Color", "dojo/number", "dojo/dom-style",
"dijit/TooltipDialog", "dijit/popup", "dojo/domReady!"
], function(
Map, FeatureLayer,
SimpleFillSymbol, SimpleLineSymbol,
SimpleRenderer, Graphic, esriLang,
Color, number, domStyle,
TooltipDialog, dijitPopup
EhabEl-Masry
New Contributor II
It is hard to guess what else you are trying to load in the "require" section, but according to your description, it seems that it is a packaging issue. Make sure that the paths you add - like "someFolder/someJavascriptModule"- is mapped to a physical resource in your web application.
Feel free to share the code..
CharlesGant
New Contributor III
require(["esri/map","esri/geometry/webMercatorUtils","esri/dijit/BasemapToggle","dojo/_base/connect","dijit/form/Button",
  "dojo/dom","dojo/parser","dojo/ready","dojo/on", "dojo/_base/Color","dojo/keys", "dojo/_base/array","dojo/number","dijit/registry",
  "esri/config","esri/SnappingManager","esri/dijit/Measurement","esri/tasks/locator","esri/graphic","esri/layers/GraphicsLayer","esri/dijit/Popup",
  "esri/dijit/PopupTemplate","esri/layers/WMSLayer","esri/layers/WMSLayerInfo","esri/urlUtils","esri/arcgis/utils","esri/geometry/Extent",
  "esri/layers/FeatureLayer","esri/layers/ImageParameters","esri/layers/CSVLayer","esri/layers/ArcGISTiledMapServiceLayer","esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/symbols/SimpleLineSymbol","esri/symbols/SimpleFillSymbol","esri/symbols/TextSymbol","esri/symbols/Font","esri/tasks/GeometryService",
  "esri/tasks/query","dojo/dom-construct","dojo/dom-style","esri/renderers/SimpleRenderer","esri/layers/LabelLayer","esri/renderers/ClassBreaksRenderer",
  "esri/InfoTemplate","esri/symbols/SimpleMarkerSymbol","esri/symbols/PictureMarkerSymbol","agsjs/dijit/TOC","dijit/layout/BorderContainer","dijit/layout/ContentPane",
  "dijit/TitlePane","esri/dijit/Scalebar","esri/TimeExtent","esri/dijit/TimeSlider","esri/layers/TimeInfo","esri/request","dojo/_base/lang",
  "dojo/date/locale","dojo/request/xhr","dojo/fx","dojo/_base/array","dijit/TooltipDialog","dijit/popup","dojo/domReady!"], function(Map, webMercatorUtils, BasemapToggle, connect, Button, dom, parser, ready, on, Color, keys, arrayUtils, number, registry, esriConfig, SnappingManager, Measurement,
  Locator, Graphic, GraphicsLayer, Popup, PopupTemplate, WMSLayer, WMSLayerInfo, urlUtils, arcgisUtils, Extent, FeatureLayer, ImageParameters, CSVLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer,
  SimpleLineSymbol, SimpleFillSymbol, TextSymbol, Font, GeometryService, Query, domConstruct, domStyle, SimpleRenderer, LabelLayer, ClassBreaksRenderer, InfoTemplate,
  SimpleMarkerSymbol, PictureMarkerSymbol, TOC, BorderContainer, ContentPane, TitlePane, Scalebar, TimeExtent, TimeSlider, TimeInfo, esriRequest, lang, locale, xhr, array, TooltipDialog, dijitPopup)
CharlesGant
New Contributor III
Could not post complete page code as it is 1500 lines.
KenBuja
MVP Esteemed Contributor
I'm not sure this is the issue, but you've added "dojo/_base/array" twice, once after Keys and once before TooltipDialog.
When I add many modules, I find it more helpful to organize them logically
require(["dojo/_base/array",
         "dojo/_base/declare",
         "dojo/_base/lang",
         "dojo/Deferred",
         "dojo/json",
         "dojo/ready",
         "dojox/gfx/fx",
         "dgrid/OnDemandGrid",
         "dgrid/Selection",
         "dgrid/selector",
         "dgrid/extensions/ColumnResizer",
         "dgrid/extensions/ColumnHider",
         "dgrid/util/mouse",
         "dgrid/extensions/DijitRegistry",
         "dijit/MenuItem",
         "dijit/layout/TabContainer",
         "dijit/registry",
         "esri/map",
         "esri/dijit/Basemap",
         "esri/dijit/BasemapGallery",
         "esri/dijit/BasemapLayer",
         "modules/DVParameters",
         "agsjs/dijit/TOC",
         "dojo/fx",
         "dojo/domReady!"
], function (array, declare, lang, Deferred, JSON, ready,
             fx,
             Grid, Selection, selector, ColumnResizer, ColumnHider, mouseUtil, DijitRegistry,
             MenuItem, TabContainer, registry,
             Map, InfoTemplate,
             Basemap, BasemapGallery, BasemapLayer, Scalebar,
             DVParameters
CharlesGant
New Contributor III
Really appreciate the reply, I removed the extra "dojo/_base/array" and still getting the error printed in console. Also removed the corresponding "array" function call.
KenBuja
Can you show the portion of your code where you use TooltipDialog?
CharlesGant
New Contributor III
All I have added in is below.  Fairly simple addition at this point.  I stopped incorporating the example after it failed here.
        dialog = new TooltipDialog({
          id
: "tooltipDialog",
          style
: "position: absolute; width: 250px; font: normal normal normal 10pt Helvetica;z-index:100"
        dialog
.startup();
