I tried searching but was surprised to not find any good results. Does anyone have a coding pattern to handle "paging" through a large query that exceeds the service's maxRecordCount property? I'd like to find a way to query the record count first, then build a bunch of query tasks with varying start and num properties to retrieve all the results. Promise.all() seems like it'd be what's needed but I can't quite wrap my head around how to make it all work. Here's my related question regarding distinct values that started this.
Blake,
Here is how I do that:
var iMaxRecords = 0;
var featuresProcessed = 0;
var featuresTotal = 0;
var maxRecordCount = layer.maxRecordCount; //normally 1000
queryTask = new QueryTask(uri);
var cntQuery = new Query();
cntQuery.where = "1=1";
queryTask.executeForCount(cntQuery, function(count){
featuresTotal = count;
if(count <= maxRecordCount){
//not an issue where you need to page
}else{
query.returnGeometry = false;
query.objectIds = null;
query.where = "1=1";
queryTask.executeForIds(query, onSearchIdsFinish, onSearchError);
function onSearchIdsFinish(results){
if (results.length > 0) {
objectIdsArray = results;
featuresTotal = objectIdsArray.length;
query.where = null;
query.text = null;
query.objectIds = objectIdsArray.slice(0, maxRecordCount);
queryTask.execute(query, onSearchFinish, onSearchError);
} else {
console.error('onSearchIdsFinish returned zero length');
isQuerying = false;
esc = false;
function onSearchFinish(featureSet) {
// do something with the results
featuresProcessed += featureSet.features.length;
if (iMaxRecords === 0) {
iMaxRecords = featuresProcessed;
iStart += iMaxRecords;
if (iStart < objectIdsArray.length) {
//If we get this far we need to requery the server for the next lot of records
query.objectIds = objectIdsArray.slice(iStart, iStart + iMaxRecords);
Interesting approach, thanks. My feature layer (hosted at 10.5.1) doesn't have a maxRecordCount property. It doesn't even have a capabilities property. Any thoughts on that?
After posting I got something that I think works. Besides the fact it doesn't work with returnDistinctValues (as I mentioned before), I'm not sure how I feel about it.
var maxRecordCount = 1000;
var queryTask = new QueryTask();
queryTask.url = 'http://server/arcgis/rest/services/ServiceName/MapServer/0';
var queryParams = new Query({
returnGeometry: false,
outFields: ['someFieldName'],
where: 'someFieldName is not null',
queryTask.executeForCount(queryParams)
.then(function(queryRecordCount) {
var pageCount = Math.ceil(queryRecordCount / maxRecordCount);
var resultPages = [];
for (var i = 0; i < pageCount; i++) {
resultPages.push(i * maxRecordCount);
return Promise.all(resultPages.map(function(resultPageStart){
queryParams.start = resultPageStart;
queryParams.num = maxRecordCount - 1;
return queryTask.execute(queryParams);
.then(function(featureSets) {
// collect features from each FeatureSet
var features = [];
featureSets.forEach(function(featureSet) {
features = features.concat(featureSet.features);
// do something with array of features
.catch(function(err) {
console.error(err);
Blake,
You can use QueryTask.exectueForCount() and in the Query object you can use returnDistinct. This will allow you to get a number that is in fact the real distinct count for your query. You then can decide if you need to use the paging route. Also the query result returns a exceededTransferLimit property that tells you if your results are not all the distinct data.
