is there a way to load a portal item from 2 different portals to a map?
for example (pseudo code),
esriConfig.portalUrl = "https://myHostName.esri.com/arcgis"
//create portal item
map.add(portalitemlayer)
esriConfig.portalUrl = "https://myHostName2.esri.com/arcgis"
map.add(portalitemlayer2)
will i be able to use both layers on the map or will the first item be severed because the portalUrl has changed.
Or can i do
portal = new Portal({ url: "https://myHostName.esri.com/arcgis" })
portal2 = new Portal({ url: "https://myHostName2.esri.com/arcgis" })
and somehow do something like
map.add(portal.portalitemlayer)
map.add(portal2.portalitemlayer2)
You could try Layer.fromPortalItem()
Layer | API Reference | ArcGIS API for JavaScript 4.8
It takes a PortalItem object, which contains a portal instance.
PortalItem | API Reference | ArcGIS API for JavaScript 4.8
You might be able to define the Portal url for the item in there.
Portal | API Reference | ArcGIS API for JavaScript 4.8
I've never tried that workflow, but I think it might work.
Would love to hear if it did!
