Multiple interceptors arcgis 4.x
1024
01-04-2022 06:02 AM
Dvirus
Arcgis 4.x JSAPI
esriConfig.request.interceptors support multiple interceptors?
ReneRubalcava
It takes an array of interceptors, each can intercept a different URL, so yes, it can.
https://developers.arcgis.com/javascript/latest/api-reference/esri-config.html#request
Dvirus
This is also what I thought but unfortunately it does not work..
Here is an pen example.
https://codepen.io/Dvirus/pen/GRMdzLW?editors=1001
ReneRubalcava
You need to specify the "urls" string so the interceptor knows which URL should be intercepted. the way you have it set up the "urls" is null or undefined, so the first one overwrites the second.
Dvirus
Thanks you! it's working!
Apparently Arcgis Experience Builder already add interceptor at file
client\dist\jimu-arcgis\index.js (it's built minified)
(e=re.request.interceptors)||void 0===e||e.push({after:e=>{var t,i;(null===(t=null==e?void 0:e.url)||void 0===t?void 0:t.indexOf("/rest/info"))&&(null===(i=null==e?void 0:e.data)||void 0===i?void 0:i.owningSystemUrl)&&this.registOAuthInfo(e.data.owningSystemUrl)}}),
 but they add interceptor without urls property
so even if I add urls
 esriConfig.request.interceptors.push({
    urls: /FeatureServer\/\d+/,
    after: function (response) {
      response.data.supportedQueryFormats = "JSON";
It's not intercept.
I tried to add urls to the first interceptor
 esriConfig.request.interceptors[0].urls = /.*?/
or
 esriConfig.request.interceptors[0].urls = /.*/
also  not working
But
when tried
  esriConfig.request.interceptors[0].urls = /blalba.*/
It's seems like if hit the first interceptor it's not continue to the second one.
Meanwhile I do
      debugger;
  esriConfig.request.interceptors.reverse();
Any suggestions?
