Move ArcGis JS API Graphic Point
4306
10-29-2018 03:26 PM
EssaddekMohammed
Is there anyway to move a created graphic point and get new coordinates ?
Regards
RobertScheitlin__GISP
Mohammed,
  Sure just combine the two samples:
<!DOCTYPE html>
<html>
<head>
  <meta charset="utf-8">
  <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
  <title>Intro to graphics - 4.9</title>
  <link rel="stylesheet" href="https://js.arcgis.com/4.9/esri/css/main.css">
  <script src="https://js.arcgis.com/4.9/"></script>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/views/MapView",
      "esri/widgets/Sketch/SketchViewModel",
      "esri/Graphic",
      "esri/layers/GraphicsLayer",
      "esri/geometry/support/webMercatorUtils",
      "esri/geometry/Polygon",
      "esri/geometry/Polyline"
    ], function(
      Map, MapView, SketchViewModel, Graphic, GraphicsLayer, webMercatorUtils, Polygon, Polyline
      let editGraphic;
      // GraphicsLayer to hold graphics created via sketch view model
      const graphicsLayer = new GraphicsLayer({
      const map = new Map({
        basemap: "gray",
        layers: [graphicsLayer]
      const view = new MapView({
        container: "viewDiv",
        map: map,
        zoom: 3
       * Create a point graphic
      // First create a point geometry (this is the location of the Titanic)
      var point = {
        type: "point", // autocasts as new Point()
        longitude: -49.97,
        latitude: 41.73
      // Create a symbol for drawing the point
      var markerSymbol = {
        type: "simple-marker", // autocasts as new SimpleMarkerSymbol()
        color: [226, 119, 40],
        outline: { // autocasts as new SimpleLineSymbol()
          color: [255, 255, 255],
          width: 2
      // Create a graphic and add the geometry and symbol to it
      var pointGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(point),
        symbol: markerSymbol
       * Create a polyline graphic
      // First create a line geometry (this is the Keystone pipeline)
      var polyline = Polyline({
        type: "polyline", // autocasts as new Polyline()
        paths: [
          [-111.30, 52.68],
          [-98, 49.5],
          [-93.94, 29.89]
      // Create a symbol for drawing the line
      var lineSymbol = {
        type: "simple-line", // autocasts as SimpleLineSymbol()
        width: 4
       * Create a new graphic and add the geometry,
       * symbol, and attributes to it. You may also
       * add a simple PopupTemplate to the graphic.
       * This allows users to view the graphic's
       * attributes when it is clicked.
      var polylineGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(polyline),
        symbol: lineSymbol
       * Create a polygon graphic
      // Create a polygon geometry
      var polygon = Polygon({
        type: "polygon", // autocasts as new Polygon()
        rings: [
          [-64.78, 32.3],
          [-66.07, 18.45],
          [-80.21, 25.78],
          [-64.78, 32.3]
      // Create a symbol for rendering the graphic
      var fillSymbol = {
        type: "simple-fill", // autocasts as new SimpleFillSymbol()
        color: [227, 139, 79, 0.8],
          width: 1
      // Add the geometry and symbol to a new graphic
      var polygonGraphic = new Graphic({
        geometry: webMercatorUtils.geographicToWebMercator(polygon),
        symbol: fillSymbol
      const pointSymbol = {
        style: "square",
        color: "#8A2BE2",
          width: 3
      const polylineSymbol = {
        type: "simple-line", // autocasts as new SimpleLineSymbol()
        color: "#8A2BE2",
        width: "4",
        style: "dash"
      const polygonSymbol = {
        color: "rgba(138,43,226, 0.8)",
        style: "solid",
        outline: {
          color: "white",
          width: 1
      view.when(function () {
        // Add the graphics to the view's graphics layer
        graphicsLayer.graphics.addMany([pointGraphic, polylineGraphic, polygonGraphic]);
        // create a new sketch view model
        const sketchViewModel = new SketchViewModel({
          view,
          layer: graphicsLayer,
          pointSymbol,
          polylineSymbol,
          polygonSymbol
        setUpClickHandler();
        // Listen the sketchViewModel's update-complete and update-cancel events
        sketchViewModel.on("update-complete", updateGraphic);
        sketchViewModel.on("update-cancel", updateGraphic);
        // Runs when sketchViewModel's update-complete or update-cancel
        // events are fired.
        function updateGraphic(event) {
          // Create a new graphic and set its geometry event.geometry
          var graphic = new Graphic({
            geometry: event.geometry,
            symbol: editGraphic.symbol
          graphicsLayer.add(graphic);
          // set the editGraphic to null update is complete or cancelled.
          editGraphic = null;
        // set up logic to handle geometry update and reflect the update on "graphicsLayer"
        function setUpClickHandler() {
          view.on("click", function (event) {
            view.hitTest(event).then(function (response) {
              var results = response.results;
              if (results.length > 0) {
                for (var i = 0; i < results.length; i++) {
                  // Check if we're already editing a graphic
                  if (!editGraphic && results[i].graphic.layer.id === "tempGraphics") {
                    // Save a reference to the graphic we intend to update
                    editGraphic = results[i].graphic;
                    // Remove the graphic from the GraphicsLayer
                    // Sketch will handle displaying the graphic while being updated
                    graphicsLayer.remove(editGraphic);
                    sketchViewModel.update(editGraphic);
                    break;
  </script>
</head>
<body>
  <div id="viewDiv"></div>
</body>
</html>
Here is a sample that allows you to draw and edit graphics.
Sketch temporary geometries | ArcGIS API for JavaScript 4.9
In this sample you can get the graphics new geometry in the updateGraphic function.
EssaddekMohammed
Hello Robert,
Is it possible to use the sketchviewmodel to edit data drawn by this code ?
Regards
Mohammed
Mohammed,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #viewDiv {
      padding: 0;
      margin: 0;
      height: 100%;
      width: 100%;
  </style>
  <script>
    require([
      "esri/Map",
      "esri/Graphic",
    ], function(
      let editGraphic;
        basemap: "gray",
        map: map,
        zoom: 3
      var point = {
        longitude: -49.97,
        latitude: 41.73
          width: 2
        paths: [
          [-111.30, 52.68],
          [-98, 49.5],
          [-93.94, 29.89]
      var lineSymbol = {
        width: 4
        symbol: lineSymbol
        rings: [
          [-64.78, 32.3],
          [-66.07, 18.45],
          [-80.21, 25.78],
          [-64.78, 32.3]
      var fillSymbol = {
          width: 1
        symbol: fillSymbol
        style: "square",
        color: "#8A2BE2",
          width: 3
        color: "#8A2BE2",
        width: "4",
        style: "dash"
        style: "solid",
        outline: {
          color: "white",
          width: 1
          view,
          pointSymbol,
          polylineSymbol,
          polygonSymbol
          editGraphic = null;
                    break;
  </script>
</head>
<body>
</body>
</html>
