function init() { loading = dojo.byId("loadingImg"); //loading image. id --> Not present, no problem var extent = getExtent(); initExtent = new esri.geometry.Extent({ "xmin":-100, "ymin":13, "xmax":-85, "ymax":24, "spatialReference":{"wkid":4326} }); //spatial reference for lat/long esriConfig.defaults.map.slider = { left:"10px", top:"10px", width:null, height:"150px" }; map = new esri.Map("map", {extent:initExtent, slider: true}); var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "JPEG"; //set the image type to JPEG, note default is PNG8. map.addLayer(new esri.layers.ArcGISDynamicMapServiceLayer("http://192.168.250.75:8399/arcgis/rest/services/surroundings/MapServer")); ground = new esri.layers.ArcGISTiledMapServiceLayer( "http://192.168.250.75:8399/arcgis/rest/services/mexLoadBal/MapServer"); dynamicMapServiceLayer09 = ground; var imageParameters = new esri.layers.ImageParameters(); imageParameters.format = "JPEG"; //set the image type to JPEG, note default is PNG8. var layer = map.addLayer(dynamicMapServiceLayer09); if (layer == null) { alert("map layer is null, could not add map layer to map"); } map.reorderLayer(ground,0); dojo.connect(map, "onClick", function(evt) { map.graphics.clear(); locator.locationToAddress(evt.mapPoint, 500); }); dojo.connect(map,"onUpdateStart",function(){ esri.show(dojo.byId("status")); showLoading(); }); dojo.connect(map,"onUpdateEnd",function(){ esri.hide(dojo.byId("status")); hideLoading(); }); dojo.connect(map, "onExtentChange", showExtent); dojo.connect(map, "onExtentChange", saveExtgent); // save Extent of the current loaded map dojo.connect(map, "onMouseMove", showCoordinates); dojo.connect(map, "onMouseDrag", showCoordinates); dojo.connect(map, "onLoad", createMenus); } /*****************************************/
Avoid "On Demand" caching! After having tiles take upwards of 3 minutes to generate with my services, ESRI eventual got back to me and said "do not use" this feature as it does not work as advertised.
