MapImageLayer Sublayers
702
12-22-2021 06:25 PM
Wade
New Contributor III
I have one service and I want several. Can this method be used directly? Will it affect the speed of the web page?
<html>
<head>
    <meta charset="utf-8" />
    <meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no" />
    <title>MapImageLayer - Toggle sublayer visibility | Sample | ArcGIS API for JavaScript 4.22</title>
    <link rel="stylesheet" href="https://js.arcgis.com/4.22/esri/themes/light/main.css" />
    <script src="https://js.arcgis.com/4.22/"></script>
    <script>
        require([
            "esri/Map",
            "esri/views/MapView",
            "esri/layers/MapImageLayer",
            "esri/widgets/LayerList"
            Map,
            MapView,
            MapImageLayer,
            LayerList
            const layer0 = new MapImageLayer({
                url: "https://sampleserver6.arcgisonline.com/arcgis/rest/services/USA/MapServer",
                title: 'MapImageLayer1',
                sublayers: [
                        title: 'Cities',
                        visible: true
            const layer1 = new MapImageLayer({
                title: 'MapImageLayer2',
                sublayers: [
                        title: 'Highways',
                        visible: true
            const layer2 = new MapImageLayer({
                title: 'MapImageLayer3',
                sublayers: [
                        title: 'States',
                        visible: true
            const layer3 = new MapImageLayer({
                title: 'MapImageLayer4',
                sublayers: [
                        title: 'Counties',
                        visible: true
            const map = new Map({
                basemap: "dark-gray-vector"
            const view = new MapView({
                container: "viewDiv",
                map: map,
                zoom: 3,
                center: [-99, 39]
            const layerList = new LayerList({
                view: view
            view.ui.add(layerList, {
                position: "top-right"
            view.on('layerview-create', (event) => {
                view.map.layers.add(layer3);
                view.map.layers.add(layer2);
                view.map.layers.add(layer1);
                view.map.layers.add(layer0);
    </script>
    <style>
        html,
        body {
            padding: 0;
            margin: 0;
            height: 100%;
            width: 100%;
        #viewDiv {
            position: absolute;
            right: 0;
            left: 0;
            top: 0;
            bottom: 0;
    </style>
</head>
<body>
    <div id="viewDiv"></div>
</body>
</html>
ReneRubalcava
If you only want the individual layers, is there a reason you don't add them as FeatureLayers? Doing multiple layers from the same map service means multiple image requests instead of one, so would be less efficient.
Wade
New Contributor III
For multiple FeatureLayers, loading time seems to be longer
