Map not loading, black screen
1113
6
03-24-2020 10:50 AM
ViktoriaMagnis
New Contributor II
Hi
I have an application that is using the JavaScript 3.30  and in some browsers the map does not load and the screen is black??
RickeyFight
MVP Regular Contributor
Viktoria Magnis
Can you share your application? What browsers is it not loading on? Is this something you have made yourself or gotten from esri?
ViktoriaMagnis
New Contributor II
There is the link
https://gis.buncombecounty.org/buncomap/
It's happening in IE.
RickeyFight
Viktoria Magnis
I am able to see the map in both IE and Microsoft Edge
I have version 11.592.18362.0
BenElan
The map works for me as well in both IE and Edge. Are there any error messages in the console when it doesn't work for you?
ViktoriaMagnis
New Contributor II
It works for me also but I have users that it doesn't work for.  I can not replicate  the problem so I can not troubleshoot it.
Noah-Sager
Sometimes there are specific Compatibility Modes in IE that can cause this issue. I would ask your users to make sure this is set to the appropriate version.
Internet Explorer: IE8, IE9, IE10, and IE11 Compatibility mode: Can't log into Claro with IE8, IE9, ...
