M to M polygons overlap each other server side
1754
04-22-2020 05:48 AM
rsharma
Hi i want to check if 2 polygons overlap each other from any of its side
rsharma
working on this link these days... please share your experience with mysql functions
database - How can I handle MySQL polygon overlap queries? - Stack Overflow
KenBuja
MVP Esteemed Contributor
You can use the geometryEngine's intersects method to test the two polygons.
rsharma
Hi Ken,
I would like to know , that if i get an array of polygons from db (assume constant) and match it with current map graphicslayer graphics geomtery, in that case how intersect will work. to match 2 arrays of geometries
KenBuja
The intersects method only compares one geometry with another. So you'd have to loop through your array, comparing each polygon with your graphic.
rsharma
don't it make my app very slow, to retrieve all users polygons(more than 1000) from db and then check on browser side with this method. one by one.
Is their any method to check it on server side.
As i have to show also that overlaped polygon, so i think it makes my app very slow
rsharma
