Locate a location in a lists
1041
12
12-27-2021 08:43 AM
altair
is it possible to have a lists of locations with (latitude and longitude), and if the user click one of the lists it will  locate and a popup will displayed its details?
jcarlson
Yes, it is possible, but it is dependent upon the context. In a Dashboard or Experience Builder, List widgets are one of the primary means of interacting with data on a linked map.
Where are you trying to implement this?
- Josh Carlson
Kendall County GIS
altair
Hello @jcarlson, thanks for answering, can you please give me an example please.
altair
arcGIS javascript API
Kishore
@altair - you can look into the JSAPI sample featurelayer-query-pagination .
Regards,
Kishore
altair
hello and thanks for this, can you provide an example using my code?
Kishore
@altair - please try implementing and post your code in codepen/sandbox to check or correct for any issue occurred.
Regards,
Kishore
altair
@Kishore please see the updated question
Kishore
@altair - change the code for correct feature with attributes:
const onLocationSelect = (location) => {
              mapDiv.current.goTo(location).then(() => {
           mapDiv.current.popup.open({
                  features:[location],
                      location.longitude,
                     location.latitude,
This should work for you.
Regards,
Kishore
altair
@Kishore Unfortunately it doesnt work
