Layer List widget won't go away
709
09-13-2020 06:08 PM
Henry7512Custer
New Contributor II
Hello,
I'm trying to toggle a Layer list widget but the code is not working. It should respond to a click event on a button that switches its value to on/off. So far it creates the widget and adds it to the map. The part that doesn't work is when trying to remove the widget.
Thank you in advance,
var boff=document.getElementById("onoff");
boff.addEventListener('click',function ()
      currentvalue=boff.value;
          if(currentvalue == "Off"){
            document.getElementById("onoff").value="On";
            view.when(function () {
              var layerList = new LayerList({
              view: view
     // Add widget to the top right corner of the view
      view.ui.add(layerList, "top-right");
  else{
          view.ui.remove('layerList');
          document.getElementById("onoff").value="Off";
KenBuja
MVP Esteemed Contributor
Declare layerList outside of the event listener and remove the quotes from line 21
let boff = document.getElementById("onoff");
let layerList;
boff.addEventListener('click', function () {
  currentvalue = boff.value;
  if (currentvalue == "Off") {
    document.getElementById("onoff").value = "On";
        view: view
  else {
    view.ui.remove(layerList);
    document.getElementById("onoff").value = "Off";
KenBuja
let layerList;
        view: view
  else {
Henry7512Custer
New Contributor II
Awesome Ken, Thank you!
