Labels in Service
522
6
02-06-2019 09:54 AM
jaykapalczynski
I am consuming this service for Railroad crossings.
When I put it in my app it renders the labels when the layer is turned off.
When I turn it on it still shows them.
I cant seem to turn them off....I want them to turn off when I turn the layer off.
Layer: Rail Crossings (ID: 0)
Any thoughts?  I am trying to below but nothing seems to work.
window.RailroadCrossings = new FeatureLayer("https://fragis.fra.dot.gov/fragis/rest/services/FRAGradeXing/MapServer/0", {
	mode: FeatureLayer.MODE_ONDEMAND,
        showLabels: false,
        onStatusChanged: {
            if(status = Enums.LayerStatusInitialized) {
               enableLabels = false;
	infoTemplate: infoTemplateRailroadCrossings,
	definitionExpression: " StateCode='51' AND POSXING='1' "
I also tried to showLabels as false on the map itself but then no other labels show up...I have them true in this example
window.map = new Map("map", {
	basemap: "gray",
	center: [-77.980586, 37.566286],
	zoom: 15,
	logo: false,
	showLabels : true
RobertScheitlin__GISP
Jay,
   This simplified code works fine for me:
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta name="viewport" content="initial-scale=1,maximum-scale=1,user-scalable=no">
<title>FeatureLayer</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.27/esri/css/esri.css">
<script src="https://js.arcgis.com/3.27/"></script>
<style>
html, body, #map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
</style>
<script>
require([
    "esri/map",
    "esri/layers/FeatureLayer",
    "dojo/domReady!"
  function(
    Map,
    FeatureLayer
    var map = new Map("map", {
      basemap: "hybrid",
      center: [-79.383417, 36.581599],
      zoom: 11,
      showLabels : true
    var RailroadCrossings = new FeatureLayer("https://fragis.fra.dot.gov/fragis/rest/services/FRAGradeXing/MapServer/0", {
      showLabels: false,
      definitionExpression: "StateCode=51 AND POSXING='1'"
    map.addLayer(RailroadCrossings);
</script>
</head>
<body>
  <div id="map"></div>
</body>
</html>
Jay,
<!DOCTYPE html>
<html>
<head>
<style>
html, body, #map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
</style>
<script>
require([
    "esri/map",
    "dojo/domReady!"
  function(
    Map,
    FeatureLayer
      basemap: "hybrid",
      zoom: 11,
      showLabels : true
      showLabels: false,
</script>
</head>
<body>
</body>
</html>
jaykapalczynski
hmmmm...interesting...Maybe something to do with having my code in a seperate js file that I am referencing and using window. to get back to the main js page....will have to look closer...
Jay,
  What is the whole
onStatusChanged
thing?
jaykapalczynski
OK I modified a bit to replicate what I have in my code....this appears to be working so it must be something else in my code that is causing this to happen...
Maybe my legend build and the button to turn on an off the layer....will look further..
<!DOCTYPE html>
<html>
<head>
<script>
var packagePath = window.location.pathname.substring(0, window.location.pathname.lastIndexOf('/'));
//dojoConfig define non-esri JavaScript source required before loading arcgis js
var dojoConfig = {
	packages: [
</script>
<script src="js/layerlist_Railroads_TEST.js"></script>
<style>
html, body, #map {
  padding: 0;
  margin: 0;
  height: 100%;
  width: 100%;
</style>
<script>
require([
    "esri/map","esri/layers/FeatureLayer","esri/InfoTemplate","dojo/_base/lang","dojo/_base/array","dojo/domReady!"
  function(
    Map,FeatureLayer,InfoTemplate,lang,array
      basemap: "hybrid",
      zoom: 11,
      showLabels : true
		// Call the JS page that has all the GRID stuff in it. Run the Functions
	window.LayerListRailroads();
		map.addLayers([
			RailroadCrossings
</script>
</head>
<body>
</body>
</html>
require([
    "esri/map",  "dojo/dom", "esri/layers/FeatureLayer","dojo/on", "dojo/_base/array", "dojo/_base/lang",
    "esri/urlUtils", "dijit/registry", "esri/arcgis/utils", "esri/domUtils",
	"dojo/_base/connect", "dojo/_base/array", "dojo/parser", "esri/InfoTemplate", "dijit/form/CheckBox",
	"dojo/dom-construct", "dojo/keys", "dojo/domReady!",
	"js/widgets","js/grids"
], function(
    Map, dom, FeatureLayer, on, array, lang,
    urlUtils, registry, arcgisUtils, domUtils,
	connect, arrayUtils, parser, InfoTemplate, CheckBox,
	domConstruct, keys
	window.LayerListRailroads = function(){
	//window.legendLayers6 = [];
// LAYER FILES =======================================================================================
	// RAILS -------------------------
		// GRAB THE DOMAIN VALUE FROM RailroadCrossings instead of the coded value
		var subTypeValRR;
		getSubtypeDomainRR = function (fieldVal, fieldName){
		  if (RailroadCrossings.typeIdField!=null) {
			  //console.log("Have Subtypes");
			  if (fieldName==RailroadCrossings.typeIdField) {
				   array.forEach(RailroadCrossings.types, lang.hitch(this, function (lsf) {
					   if (fieldVal==lsf.id){
						   fieldVal=lsf.name;
						   subTypeValRR=lsf.id;
			  } else {
					   if (lsf.id==subTypeValRR){
						   array.forEach(lsf.domains[fieldName].codedValues, lang.hitch(this, function (domain) {
							  if (fieldVal==domain.code){
								  fieldVal=domain.name;
		  } else {
			  //console.log("No Subtypes");
			  subTypeValRR=null;
			  array.forEach(RailroadCrossings.fields, lang.hitch(this, function (ldf) {
				  if (ldf.name==fieldName){
					  if (ldf.domain){
						  array.forEach(ldf.domain.codedValues, lang.hitch(this, function(domain){
		  return fieldVal;
		var infoTemplateRailroadCrossings = new InfoTemplate();
			infoTemplateRailroadCrossings.setTitle("Railroad Crossingss");
			infoTemplateRailroadCrossings.setContent("<table>" +
			"<tr><td id='tblTitle'>Railroad Crossing</td><td id='tblTitle2'></td></tr>" +
			"<tr><td id='tblTitleLine'></td><td id='tblTitleLine2'></td></tr>" +
			"<tr><td></td><td></td></tr>" +
			"<tr><td id='tblMainline1'>crossing</td><td id='tblSubline2'>${CROSSING}</td></tr>" +
			"<tr><td id='tblMainline1'>date</td><td id='tblSubline2'>${EFFDATE}</td></tr>" +
			"<tr><td id='tblMainline1'>reason</td><td id='tblSubline2'>${REASON:getSubtypeDomainRR}</td></tr>" +
			"<tr><td id='tblMainline1'>rr</td><td id='tblSubline2'>${RAILROAD}</td></tr>" +
			"<tr><td id='tblMainline1'>rr division</td><td id='tblSubline2'>${RRDIV}</td></tr>" +
			"<tr><td id='tblMainline1'>rr subdivision</td><td id='tblSubline2'>${RRSUBDIV}</td></tr>" +
			"<tr><td id='tblMainline1'>highway</td><td id='tblSubline2'>${HIGHWAY}</td></tr>" +
			"<tr><td id='tblMainline1'>street</td><td id='tblSubline2'>${STREET}</td></tr>" +
			"<tr><td id='tblMainline1'>milepost</td><td id='tblSubline2'>${MILEPOST}</td></tr>" +
			"<tr><td id='tblMainline1'>crossing type</td><td id='tblSubline2'>${TYPEXING:getSubtypeDomainRR}</td></tr>" +
			"<tr><td id='tblMainline1'>crossing pos</td><td id='tblSubline2'>${POSXING:getSubtypeDomainRR}</td></tr>" +
			"<tr><td id='tblMainline1'>rrcont</td><td id='tblSubline2'>${RRCONT}</td></tr>" +
			"<tr><td id='tblMainline1'>inv link</td><td id='tblSubline2'><i>For more INV information please <a href='${INV_LINK}' target='_blank'><font color='0x84CCDA'>click here</font></a>."+
			"<tr><td id='tblMainline1'>acc link</td><td id='tblSubline2'><i>For more ACC information please <a href='${ACC_LINK}' target='_blank'><font color='0x84CCDA'>click here</font></a>."+
			"</table><hr>");
			showLabels: false,
			visible: true,
			opacity: 0.5,
			outFields:["*"],
		// Set Definition Criteria
		//RailroadCrossings.setDefinitionExpression(" StateCode='51' AND POSXING='1' ");
		// Push to Layer List
		//legendLayers6.push({ layer: RailroadCrossings, title: 'Railroad Crossings' });
// END LAYER FILES =======================================================================================
		} // End of LoadLayerList
	});  // End fo require
Jay,
   Although your definitionExpression is working, it is incorrect. The StateCode field is an integer and you have 51 in single qoute when it should not contain any qoutes when working with numbers in SQL.
jaykapalczynski
I found the error...it was in an unrelated function regarding a find near me tool....while I did not pin point the issue at this time I was able to comment out the code and remedy the problem.
Thank you Robert for pointing out the fact that the code and service was working.  It took me down another path that allowed me to see the real issue.  Much appreciated.
